Results 1 to 4 of 4
Thread: Having problem with dashboard.
    Apr 2008
    Default Having problem with dashboard.
    I am connecting to an LMM Duramax ECM. When I goto dashboard the default gauge page shows the gauges but not working like not reading anything. If i hit the yellow button on the dashboard section I get the following error. Now I have activated the DVT and they work at this same point so it seems connected to me since I raise and lower engine RPM from the DVT. I have installed the latest
    EfiLive 7.5.5 build 77
    EfiLive Explorer 8.1.2 build 44
    Bootblock 2.06.02
    Firmware 2.06.06
    Now it has worked before but that was before the last update. I had build 7.5.5 build 72 and 8.1.* build 42 and worked for me then on same notebook and usb port.
    This a portion of the error log.
    Code:
    Error report generated by EFILive at 18:02:38 on Dec 29, 2008
    Error code: ERR_IGNORED/4
    No response from vehicle.
    EFILive Version: 7.5.5 (Build 77)
    Platform: Windows NT
    Version: 6.0 (build 6001)
    Processor type: Pentium 2261MHz
    Directories
      Temporary Cache: C:\Users\crusher65\Documents\EFILive\V7.5\Temporary cache
      Logged Data: C:\Users\crusher65\Documents\EFILive\V7.5\Logged data
      Customers: C:\Users\crusher65\Documents\EFILive\V7.5\Customers
      Configuration: C:\Program Files\EFILive\V7.5\Configuration
      Exported Data: C:\Users\crusher65\Documents\EFILive\V7.5\Exported data
      Images: C:\Users\crusher65\Documents\EFILive\V7.5\Images
      Sounds: C:\Users\crusher65\Documents\EFILive\V7.5\Sounds
      Maps: C:\Users\crusher65\Documents\EFILive\V7.5\Maps
      Pids: C:\Users\crusher65\Documents\EFILive\V7.5\PIDs
      Virtual Dash: C:\Users\crusher65\Documents\EFILive\V7.5\VDash
      Print Reports: C:\Users\crusher65\Documents\EFILive\V7.5\Print reports
      Bug Reports: C:\Users\crusher65\Documents\EFILive\V7.5\Bug reports
    Connected: No
    Com port: 0
    Com setup: EFILive FlashScan V2.5: USB
    Requested baud rate: 115200
    Cable id: 7
    Cable code: FlashScan V2
    Cable desc: EFILive FlashScan V2
    Cable version: 2.6.6
    Cable Firmware date: 20081214
    Cable model: FSV2
    Cable Serial number: 003684136154
    Protocols: 0
    Protocol list:
    Auto connect: No
    Scan OBDII info: No
    Error retries: 1
    Retry delay: 10
    Message throttle: 0
    Most recently used VIN: 1GCHK236X7Fxxxxxx (Note: 1)
    PCM information
      Hardware Number: Unknown
      Calibration ID: 12617102
      Serial Number: 86J701301280
      Operating System: 12628596
      Not used: 12628594
      Not used: 12628713
      Transmission: 12628594
      Not used: 12628702
      Not used: 12628695
      Not used: 12628694
      Not used: 12628715
      Operating System BCC: YRLF
      Stream-Slow scan mode: Supported
      Stream-Fast scan mode: Supported
      Maximum dynamic packets: 16
    Detected modules:
    Selected parameters:
      CALC.G_FORCE=1,4286
      CALC.POWER_RW=1,4300
      GM.BALRCYL1=1,4401
      GM.BALRCYL2=1,4402
      GM.BALRCYL3=1,4403
      GM.BALRCYL4=1,4404
      GM.BALRCYL5=1,4405
      GM.BALRCYL6=1,4406
      GM.BALRCYL7=1,4407
      GM.BALRCYL8=1,4408
      GM.BAROV=1,4411
      GM.BOOST2_DMA=1,4415
      GM.EGT2A=1,4481
      GM.FLS=1,4555
      GM.FRPCOM=1,4563
      GM.FRPDES=1,4565
      GM.FRPSV=1,4566
      GM.IAT2=1,4620
      GM.MAIN1Q_DMA=1,4689
      GM.MAIN1T_DMA=1,4690
      GM.MNINJTIM=1,4733
      GM.PILOT2T_DMA=1,4780
      GM.TCVPOS=1,4839
      GM.WIFV=1,4902
      SAE.BARO=1,4913
      SAE.ECT=1,4928
      SAE.FLI=1,4935
      SAE.FRP_C=1,4938
      SAE.IAT=1,4941
      SAE.MAF=1,4946
      SAE.RPM=1,4967
      SAE.VSS=1,4983
    Thanks for your time and help.
    Brian
    Try reducing the number of selected channels of PIDs to 24 or less.
    That is not the same as 24 PIDs. Some PIDs use multiple channels.
    You can see the selected channel count at the bottom of the PID selection panel on the [PIDs (F8)] tab page.
    Apr 2008
    Thanks for the reply. I have unselected all of them already after posting. Been trying stuff from this post to no avail. Post #14 http://www.dieselplace.com/forum/sho...ight=dashboard
    This is on a vista 32bit system. I will give it a fresh try in the morning. Also this is from the console when connecting.
    Code:
    20:44:46.085: Disconnecting ...
    20:44:46.756: CAN-VPW Bridge Deactived
    20:44:46.756: Disconnected
    20:44:51.389: Scanning for EFILive FlashScan V2 USB
    20:44:51.405: Autodetect interface ...
    20:44:53.277: Interface not detected
    20:44:53.947: Scanning for EFILive FlashScan V2 HAPI
    20:44:53.963: Autodetect interface ...
    20:44:54.150: Interface firmware version: 2.6.6
    20:44:54.150: Connection to [FSV2] interface is OK
    20:44:54.166: CAN-VPW Bridge Actived
    20:44:54.181: Current protocol set to: "ISO 15765 CAN"
    20:44:54.181: Autodetect PCM...
    20:44:56.256: PCM not detected.
    20:44:56.256: Autodetect ECM...
    20:44:56.303: Connection to ECM is OK
    20:44:56.303: Autodetect TCM...
    20:44:56.334: Connection to TCM is OK
    20:44:56.365: Current protocol: "ISO 15765 CAN"
    20:44:56.412: Interface firmware model: FSV2
    20:44:56.428: Interface firmware version: 2.6.6
    20:44:56.459: Interface firmware date: Dec 14, 2008
    20:44:56.490: FlashScan serial number: 003684136154
    20:44:56.506: FlashScan license number: 003684136154
    20:44:56.568: Request GM VIN...
    20:44:57.286: VIN: 1GCHK236X7F501266
    20:44:57.286: Request serial number...
    20:44:58.159: Serial number: 86J701301280
    20:44:58.175: Request hardware number...
    20:44:58.315: Request GM operating system...
    20:44:58.347: GM operating system: 12628594
    20:44:58.347: Request GM NVM...
    20:44:58.643: GM NVM: 12617102
    20:44:58.643: Request GM Engine calibration...
    20:44:58.674: Request GM Engine diagnostics...
    20:44:58.705: Request GM Transmission calibration...
    20:44:58.737: Request GM Transmission diagnostics...
    20:44:58.768: Request GM Fuel system...
    20:44:58.799: Request GM System...
    20:44:58.830: Request GM Speedometer...
    20:44:58.861: Request GM BCC...
    20:44:59.142: GM BCC: YRLF
    20:44:59.158: Request GM VAT/IGN Cycles...
    20:44:59.189: GM VAT/IGN cycles: 0
    20:44:59.189: Request GM oil life...
    20:44:59.220: Query support for stream.01 scan mode...
    20:44:59.641: Query support for stream.02 scan mode...
    20:44:59.797: Calculating number of dynamic packet ID's...
    20:45:00.640: Loading generic configuration file: sae_generic.txt
    20:45:00.655: User defined calculated PIDs file: calc_pids.txt
    20:45:00.655: Enhanced configuration file: gm_enhanced.prn
    20:45:01.155: Request GM VIN...
    20:45:01.857: VIN: 1GCHK236X7F501266
    20:45:01.981: Request GM operating system...
    20:45:02.013: GM operating system: 12628594
    20:45:02.028: Validating PIDs...
    20:45:02.091: Validating Modules...
    20:45:02.137: Searching for: "Powertrain Control Module (PCM)"
    20:45:04.165: Searching for: "Engine Control Module (ECM)"
    20:45:06.193: Searching for: "Transmission Control Module (TCM)"
    20:45:08.409: Initialising PIDs...
    20:45:08.565: Initialising Modules...
    20:45:08.580: Ready.
    Thanks again for your time and help Paul.
    Apr 2008
    I now have it working. The new change I made today was select the Duramax Imperial PID set. I made a new pid set and thought I could use it that way so as not to change the default. So selecting the pid set and all works.
    Thanks for your help Paul.
    Brian
  1. Scanner Dashboard Problem...need a little assistance
    By exploder in forum General (Petrol, Gas, Ethanol)
    Last Post: July 24th, 2009, 09:20 AM
  2. dashboard configuration
    By veee8 in forum FlashScan V2
    Last Post: August 2nd, 2008, 12:08 AM
  3. Looking for dashboard thats in the manual!
    By Redline Motorsports in forum General
    Last Post: September 12th, 2007, 04:04 AM
  4. Another TDC day, Hey I need a new Dashboard
    By NewV in forum Tips and tricks
    Last Post: January 18th, 2007, 02:48 PM
  5. Dashboard plots
    By jlakowicz in forum General
    Last Post: May 1st, 2005, 07:14 PM
