Results 1 to 4 of 4
Thread: Absolute Throttle Position
    Aug 2007
    Default Absolute Throttle Position
    While doing a test log to see if my wideband was working, I noticed that the absolute throttle position stayed at 19-20% at idle. Is this what it should be at? I figured it should be around 5% or so at idle. Is this normal?
    This is the log with the stock tune.
    Jan 2007
    May help to post some details relating to type of vehicle?
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Aug 2007
    05 gto e40 ls2
    Oct 2004
    Try logging the ETC (Electronic Throttle) PID GM.ETCTP which will probably give you different results
    Andrew
    EFILive Crew
  1. Throttle position confuddlement
    By turboberserker in forum General (Petrol, Gas, Ethanol)
    Last Post: June 2nd, 2010, 06:18 AM
  2. 2010 throttle position values ??
    By 2010 Bumblebee in forum E37, E38 & E67 PFI ECM's
    Last Post: May 7th, 2010, 02:19 AM
  3. Pedal position vs. commanded TAC position weirdness
    By gmtech16450yz in forum E37, E38 & E67 PFI ECM's
    Last Post: November 1st, 2009, 11:48 AM
  4. Throttle position 256%
    By vatman02 in forum General
    Last Post: September 27th, 2007, 05:08 PM
  5. Replies: 11
    Last Post: May 8th, 2005, 11:52 PM
