Results 1 to 10 of 17
Thread: defueling at 210 deg.
    Dec 2008
    Default defueling at 210 deg.
    Truck runs fine til. temp gage hits 210 deg., Then is like it goes back to stock tune. Just wondering if anyone has heard of this. Thanks
    Senior Member DmaxHawk's Avatar
    Apr 2008
    What type of tune are you running? DSP5, DSP2, single flash? What engine do you have? I assume you have an LB7?
    07 El Bee Zee
    Little faster than stock...
    Dec 2008
    I have a lb7 engine, This is a single flash. The tune is bullydog pup, that I added fuel to. To make it smoke alittle
    Dec 2008
    I have engine codes,po234 turbo eng. overboost, po089 fuel pressure regulator 1 performance, po101 mass air flow senser performance. Just thought this would help out.
    Apr 2008
    I havent heard of anything like that. I would try copy and pasting all the fuel and boost tables from the bullydog onto your stock tune and try that.
    07 El Bee Zee
    Aug 2007
    The 234 over boost code will cause defuel. Go to C0301 and set these to not reported. That should solve the "Limited Power" issue. I had the same problem when I went to a different turbo. It may not be necessary for all 4, but that's what worked for me.
    Dec 2008
    Thanks I tried that and it works fine.Thanks for all your help.
    Aug 2007
    are you running a K&N type filter?
    Apr 2008
    Quote Originally Posted by mvnvltn View Post
    Good question, or any other oil-type filter
    07 El Bee Zee
    Aug 2007
    Are you using a lift pump? What is your max inj pulse?
  1. Where to look for a 3 to 4 defueling issue?
    By Tarkstoys in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 8th, 2010, 02:29 PM
  2. dsp5 defueling
    By SGFastMax in forum Duramax LB7
    Last Post: February 15th, 2010, 03:23 AM
  3. defueling for quicker shifts on a zf-6?
    By relentless addiction in forum Duramax LB7
    Last Post: July 9th, 2009, 02:17 PM
  4. LMM defueling
    By camcojb in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 13th, 2007, 12:47 PM
