Page 3 of 9 FirstFirst 12345 ... LastLast
Results 21 to 30 of 89
Thread: 427 L92 a4 GTO issue
  1. #21
    Mar 2007
    You checked compression and leakdown in all 8 holes?
    Compression tells you if a ring is fried. Leakdown tells you if valves are fried or not opening/closing.
    This is a new motor, right? Is it possible a valvespring broke? I'd pull the valve covers just to give it a look see. Easy thing to do (well, on my truck anyway).
    I'm wondering why it layed down at half track. Layed down on a shift too I assume? Overrevved? Did you hit 2nd instead of fourth and hit 8000 RPM?
    Is it possible that a valve came in contact with a piston at high RPM (valve float) and now all your valves are bent, leading to no compression? You may not float the valves normally but you could float them on a mis-shift. I have also seen this happen. Your setup is extreme (427) so I'd imagine the least room for error.
    Just trying to be of assistance. May not be EFI related, but hard parts related.
    Please let us know what you find! I am very very interested to know.
    Car has no catalytic converters right? Maybe a high EGT melted the substrate inside the cat into a ball. The ball is now blocking your exhaust. Happened to me before.
    Eric / Stealth
  2. #22
    If it was good (1st pass: 11.60@ 120) and then in a short time it was no good (2nd pass: 12.55 @105, "layed down at 1/2 track"), then something broke/bent...
    Have you considered any of these:
    - timing chain jumping,
    - pushrods, rockers, springs, lifters, cam, valve (as Eric/Stealth said),
    - cam walking,
    - CKP reluctor hitting/bending,
    - CKP and/or CMP sensor failure,
    - other sensor failure,
    - air leak in intake/exhaust,
    - blockage in exhaust.
    Are you running MAF or MAF-less (your MAF pid is all zero)...?
    And set C0805 to an in-range value (altho I don't think that's it).
  3. #23
    Jun 2006
    Quote Originally Posted by 10secvette View Post
    While looking the car over in the pits, I discovered a hanging ground wire off the drv. side head. I figured I had found the problem. Put the ground back on and no improvement. At this point the car would hardly idle, and was backfiring throught the intake.
    I think this may have fried the ecm.
    The front of the motor came off, no timing chain issue. CPS was changed along with all of the other engine sensors. Microscope was used to check the reluctor, ok. No vac. leaks. No cats on the car at the track. No maf.
  4. #24
    Mar 2007
    - cam walking,
    Agreed. I was just coming back to say is it possible the timing chain jumped a tooth or something?
    No DTC's? Do you have a MIL malfunction indicator light? I'd check for DTC's also.
    Quite possibly is the intake manifold leaking somehow (you say it backfired, did it break. Is it a sheet metal intake? One N20 explosion and it breaks at the welds. Repair it?). I know you aren't nitrous but any backfire of pressure could possibly break it.
    Throwing out ideas trying to help. Lets get this thing fixed!
  5. #25
    Mar 2007
    What state are you in? If you lived near me you could borrow my spare ECM. I live near joecar in Los Angeles, CA.
  6. #26
    Jun 2006
    Quote Originally Posted by Stealth97 View Post
    No dtc's.
    I borrowed a tech 2 and scanned everything, nothing tripped. I swapped intakes, no change. I appreciate the idea's. I think I've gone through or swapped about everything I could think of besides the major control modules. It's frustrating because I've been messing around with LSx motors for 10 years now and this one has me stumped.
  7. #27
    Jun 2006
    Damn, I'm in Murrieta, near Temecula. I'm in and out of LA every week. I appreciate the offer, I would have taken you up on it but my new one should be hear Monday or Tuesday.
    I will say this, if the ecm is not the issue, I have plenty of beer in the fridge about 20 inches from the nose of the car for whoever wants to come over and troubleshoot with me.
  8. #28
    Murrieta... I'll have to ask my Mrs for permission...
  9. #29
    Jun 2006
    Bring her along, she can go wine tasting or shopping w/my wife.
  10. #30
    She'll want to go to the casino...
    I'll check my GM service manual for 2005 GTO.
  1. New Guy with TCC Issue
    By OldGreg in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 30th, 2009, 04:21 PM
  2. LC-1 Issue
    By jermstyle in forum General (Petrol, Gas, Ethanol)
    Last Post: January 6th, 2009, 10:36 AM
  3. BBL and E38 COS Issue
    By swingtan in forum FlashScan V2 BB Logging
    Last Post: October 29th, 2008, 11:00 AM
  4. New Issue
    By jamesbond2509 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 16th, 2006, 10:07 PM
