Results 1 to 4 of 4
Thread: Rafig/Rafpn not working???
    Jan 2007
    Default Rafig/Rafpn not working???
    OK all....
    I recently noticed Rafig/Rafpn was no longer working for me.
    I believe it started after going through the idle tutorial process.
    Can anyone have a look at these two tunes (first one working...second not working) and see if you can pick what would stop it working.
    Also attached a log of the Rafpn process so you can see what's happening.
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Lifetime Member Biggsy's Avatar
    Jan 2007
    Well in the first tune the idle learn min temp is set to 120 Deg C {B4501} and second is set to 71 Deg C
    Are you sure its the second one thats not working?
    Dave.
    Jan 2007
    Yep....it's deffinately the second one that's not working.
    Howard
    DUCT TAPE.
    Jan 2007
    Here's a RAFPN from this morning...on the first tune posted above.
    Howard
    DUCT TAPE.
  1. Trying to tune RAFPN and RAFIG
    By z28ls1818 in forum Gen III V8 Specific
    Last Post: January 13th, 2010, 05:39 PM
  2. Tuning RAFIG and RAFPN NEED HELP PLEASE
    Last Post: December 28th, 2009, 03:24 AM
  3. RAFIG RAFPN for E40
    By MyM8V8 in forum Gen IV V8 Specific
    Last Post: March 31st, 2009, 09:50 AM
  4. RAFIG/RAFPN when running with MAF sensor????
    Last Post: March 3rd, 2008, 01:57 PM
  5. Start-up Idle issues. This isn't a RAFIG/RAFPN issue
    By RandomHero in forum General (Petrol, Gas, Ethanol)
    Last Post: April 20th, 2007, 11:34 AM
