I installed an LC-1 this weekend and I'm having some trouble reading the data. I used the serial connection, ran new power/ground wires from the ignition/block and soldered all connections. At first everything worked flawlessly, I configured my V2 and was reading the AFR.
After 30 minutes or so it stopped giving a serial signal to my V2. I tried to connect to the controller with the LM Programmer software and it's unable to connect from that either. The LED on the LC-1 warms up and then goes on steady like its working. Any ideas? I'm going to call innovative on Monday but I'd like to get it working this weekend.
