Results 1 to 10 of 15
Thread: E38 Fan Patch issue.
    Lifetime Member johnsZ06's Avatar
    Sep 2003
    Default E38 Fan Patch issue.
    When i apply the fan patch, i can't see any values below 192*F. Can someone please enlighten me as to what i'm doing wrong.
    Thanks.
    Oct 2005
    Paul was going to fix that problem in the tune tool... I think he might have missed it off his "to do" list
    It works, but you cant see the correct new numbers. Maybe ping support@efilive.com a email about it. I have the same problem.
    2014 VF SV LS3 Maloo.
    Sep 2003
    Weird thing is, the first time I ever applied it, it worked. The two tunes following, does not reveal the lower temp tables.
    I have no idea how to scale the fans for lower temps when I can't see the tables.
    Lifetime Member izaks's Avatar
    Aug 2003
    From an earlier post:
    Follow the normal process to apply the patch.
    Then open G0901. The first vaue is still 89'C, but it repesents a value about 9'C lower.
    If you want to activate the fans at 90'C, then change the % in the 99'C label.
    You might have to play with values to get the desired values.
    2011 VE SSV 419 + CAM + Whipple 2.9FF SC + PPV front struts + Bilstein rear shocks + 6L90E with single piece carbon fiber prop
    Oct 2005
    Quote Originally Posted by johnsZ06 View Post
    Yep, I bet you upgraded the software between those 2 times too
    Sep 2003
    So I'm SOL I guess?
    So I'm SOL I guess?
    No, you're not out of luck.
    It should work fine. The patch is applied and you're good to go. Just the labels on the table are not showing the correct values. As Izak said, after the patch is applied, "assume" the labels are correct.
    I will fix it in the next update its now on the whiteboard so it can't get forgotten again.
    After the patch is applied, the labels should be assumed to displayed as:
    Degrees C:
    76,78,81,84,87,90,92,95,98,101,104,106,109,112,115 ,118,121
    Degrees F:
    168,172,177,183,188,194,197,203,208,213,219,222,22 8,233,239,244,249
    Sep 2003
    Degrees C:
    Degrees F:
    I see. So I need to transpose the current temp figures for the ones above.
    Cool. That was easy.
    Thank you kind sir.
    Dec 2007
    Degrees C:
    Degrees F:
    Thankyou sir!
    Had previously noticed that fan 1 turned on at about 45%, fan 2 @ 90%. Is this still the same with the expanded scale?
  1. Lbz cvn patch ?!?!?!
    By bballer182 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 5th, 2009, 04:53 AM
  2. MAF Patch Question
    By 860 in forum Gen IV V8 Specific
    Last Post: June 4th, 2008, 05:01 PM
  3. Boosted E40 -- MAF patch?
    By Tony @ MPH in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: February 1st, 2008, 05:36 PM
