Thread: Changing the BCM
    Sep 2008
    Default Changing the BCM
    I have a 02 Trailblazer 4x4 and I like to know is it possible to change the BCM with efilive? Becuase Im trying to add something in it and remove an optial equipment. If not what can we use to change the BCM
    Nov 2006
    you can "re-link" the PCM to a new BCM,
    but you cannot change the BCM itself.
    LC-1 WBO2
    Sep 2008
    so your saying just buy a new one then get gm to reprogram it?
    May 2008
    The tech 2 can flash the BCM with different images, but you can't change settings in it. If you can find one from the same vehicle with the features you want, you can jot down that vin number and have the dealer flash the BCM with that image.
    E85 is NOT flex fuel.
    2003 Chevy S10 4.3L LU3 LS1B Auto
    48 LB injectors
    Race Proven Motors 2114 intake
    T70 turbo.
    Sep 2008
    alright I found one vin but the problem is the other vin dont have bose sound and losethe heat and signal side mirrors.
    but ive heard some people were able to install the side mirrors with signal and heater deforster when originally these features were not included in their viehicle. How is that possible?
    May 2008
    The cars equipped with the manual mirrors may still have the BCM functionality to handle power windows. About the only experience I have had was converting a pickup to use DRL/fog lamps. It would have been a lot easier if I had software that could see features the vehicle was equipped with, but it doesn't seem to exist. It would be so nice to be able to set/display default light settings, door switches, and radio settings.
    You can look up the calibration part numbers on the tis2web.service.gm.com
    48 LB injectors
    T70 turbo.
  1. Changing AFR
    By philsz06 in forum Gen III V8 Specific
    Last Post: May 7th, 2010, 12:42 PM
  2. Changing OS
    By lownslo in forum Gen III V8 Specific
    Last Post: October 30th, 2009, 03:40 AM
  3. Changing IFR
    By Beer99C5 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 28th, 2006, 05:40 AM
  4. Value changing: is this possible?
    By AGRO in forum RoadRunner Real-Time PCM Emulator
    Last Post: September 25th, 2006, 06:51 AM
  5. changing from F to C
    By batesyellow01 in forum General (Petrol, Gas, Ethanol)
    Last Post: July 21st, 2006, 07:28 AM
