Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: 2006 MAX no PE ?
    Jun 2006
    Default 2006 MAX no PE ?
    hey guys, ive been workin on a tune for an 06 k1500 with the max 6.0 in it. ive got the tune working good, but , i cant get pe to enter when i want it. ive been looging it on the dyno,, and it seems that on the third pull it finally goes in. is there something that im missing ?? why wont pe enter as it is commanded ?
    Try setting B3609 to zeros.
    You need at least 70% throttle to get PE, is TPS indicating better than 70%...?
    Jun 2006
    thanks joe, i tryed that. that didnt help.i am getting to 100% throttle, still,, you have to make 3 pulls til it goes into pe. it does that on the street too. you can feel a differance in the truck when the pe goes in.
    i remember reading on the hp forum that there was something with the 2006 trucks that prevented them from going into pe to save fuel. i have tuned other years silverados , they never seemed to have a problem getting into pe with a tune like this ??? im stumped.
    I can't see anything in the tune file that would prevent it.
    Aug 2008
    Try setting tables B3644, B3645 to about 1.3 or higher and also try lowering B3616 to 50% or lower.......
    FLASHSCAN V2 & AUTOCAL
    Aug 2008
    Are you getting any knock/pinging at WOT? Your B3618 (TO ME) is scary "LEAN"......
    Good point, B3644 is zero, I missed that...
    Jun 2006
    thanks guys. i'll give that stuff a try. im not sure i understand how B3644 works, my thinking was that it is the time in secs that the pe transfered in ?? org tune it was .1
    i am not getting any pinging at wot. i set B3618 to that value as a test, because when the truck does go into pe, after the 3rd pull,, it was at 10.8 for fuel on the wide band, i tryed to cheat it to go leaner.
    Jun 2006
    ok, i tryed that. it seems to go into pe, but not when it should. why wont it go into pe when the throttle gets past 50 %, it takes like 3 secs or more at wot before it finally goes into pe ?? i know im missing something
    Aug 2008
    Have you tried messing around with the Traction Control tables? Also, try disabling the B0701 CatOvertempertature(COT)....When enabled, it richens up the mixture(quite-a-bit) to protect the Cats...especially at WOT!!!!!
    Can you post up some Data Logs? Kinda hard to help with no data logs to view........
  1. Nitrous COS for 2006 E40?
    By KAZ MotorSports in forum Gen IV V8 Specific
    Last Post: May 23rd, 2008, 02:51 PM
  2. COS for 2006 OS
    By MoTruck in forum Custom Operating Systems
    Last Post: July 9th, 2007, 01:07 PM
  3. 2006 Torrent?
    By Cougar281 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 25th, 2007, 11:52 AM
  4. November 14, 2006 v7.3.3 is now available.
    By Whippled 496 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 29th, 2006, 03:00 AM
