Results 1 to 10 of 15
Thread: gauge cluster message
    Oct 2008
    Default gauge cluster message
    I have seen it but I dont know how to do it. How do you program your gauge cluster to display a message that you entered in to it with efi live?
    Four stroke diesel S.S.B.B. Suck Squeez Bang Blow
    06 LBZ with 5 inch magnaflow exhaust,Bd exhaust manifold, Bully dog outlook, Egr blocker, Firestone air bag system,Custom sound system, dual fuel filters,leveling kit, B&M deep tranny pan,TTS lift pump,Turbo Resonator plugged,Cooper ST 265/75R16, Bully nerf bars and B&W guardian headache rack sprayed with reflex bed liner, B&W turn over ball,B&W Tow&Stow, transgo jr, efi live Tuned By IdahoRob,tranny filled with transynd
    WWW.ATPTrucks.COM
    I believe it is the file Messages.txt located in My Documents\EFILive\V7.5\User Configuration.
    There are some caveats to displaying a message, I believe it will only display during flashing.
    And won't work on your LBZ, it's only for earlier vehicles.
    Oct 2008
    damn it will they ever get it to work on the LBZ?
    WWW.ATPTrucks.COM
    Lifetime Member Cougar281's Avatar
    Jan 2006
    Quote Originally Posted by FH Leader View Post
    Doubt it. 01-05 the programming was done over the Class 2 bus. 06+ programming is done over the HS GMLAN bus, and the cluster is on Class 2. 07.5+, programming is done on HS GMLAN, and the cluster is on LS GMLAN, which might not even come back to the DLC. slipping the message in on the class2 bus just before programming is easy. It's not as easy to try to send the messages on a differnt bus than the one you're programming on.
    Lifetime Member Chuck CoW's Avatar
    Feb 2006
    Default He he..Check here!
    He he..Check here!
    Chuck CoW
    CoW BOOSTER! Electronic Throttle Enhancement.
    - CLICK HERE NOW FOR MORE INFORMATION! -
    VARARAM, EDELBROCK, AMERICAN RACING HEADERS, BAER BRAKES, BORLA, EFI Live, Magnuson,
    COMP Cams, PROCHARGER, PRO TORQUE, PHADT Racing, INNOVATORS WEST, and more.
    Jan 2006
    Quote Originally Posted by Chuck CoW View Post
    He he..Check here!
    Chuck CoW
    I'm sure you're doing something other than slipping a message onto the data bus just before and after programming . I can make my cluster say whatever I want too
    Jul 2009
    how exactly do you do that? and it only display the text when flashing??
    Feb 2011
    Quote Originally Posted by BBdiesel View Post
    I'm wondering the same thing for a 06LLY , 07LBZ truck and a 04 Gas engine truck that has the 6.0 Vortec?
    Having the custom message at vehicle startup would be sooooo cool !!
    Thanks !!!
    Quote Originally Posted by KB3MMX View Post
    Thanks !!!
    EFILive cant do it, it only lets the custom message flash across the DIC when reading/flashing because the EFILive bootloader is working in the PCM/ECM at that time and it is the bootloader that can display the message.
  1. Cluster Message
    By L31Sleeper in forum General (Petrol, Gas, Ethanol)
    Last Post: May 30th, 2010, 09:31 PM
  2. 06 LLY Fuel Gauge - empty gauge with 7 gallons left
    By timvan in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 5th, 2009, 02:35 PM
  3. Changing Mileage in New Gauge Cluster
    By Ninety8C5 in forum Lounge
    Last Post: July 5th, 2009, 12:39 PM
  4. cluster question
    By justin123 in forum Gen III V8 Specific
    Last Post: June 1st, 2009, 01:19 PM
  5. Replies: 4
    Last Post: July 6th, 2008, 04:34 AM
