Results 1 to 10 of 10
Thread: 03 lb7 duramax
    Jan 2009
    Default 03 lb7 duramax
    having some prob. w/truck...intermitenly will only crank and run for 10-12 seconds then just die and will not crank for 5-10 min. after i hit the primer 5-6 times..any help would be greatly appreciated..thanks
    Senior Member DmaxHawk's Avatar
    Apr 2008
    When was the last time you changed your fuel filter? Is there a leak when you prime?
    07 El Bee Zee
    Little faster than stock...
    Jan 2009
    Default lb7 duramax
    6000-7000 on filter from gm no leaks that i can tell no smell of diesel either
    Apr 2008
    I ask because it sounds like you are loosing your prime some how.
    07 El Bee Zee
    Jan 2009
    6000-7000 on filter no leaks that i can tell no smell of diesel either
    Jan 2009
    thats what mech. at work tell me...one said they were havin prob. w/injectors leaking back to cylinders
    Jan 2009
    but it does this one day then may go 2-3 days before it happens again runs like normal in between and after it does crank
    Apr 2008
    Are you throwing any codes?
    07 El Bee Zee
    Jan 2009
    did diag sun. night and no codes came up
    Aug 2007
    Any work on the engine lately? If so what type? How many miles on it?
  1. Duramax Tuning
    By kurtfromct in forum General (Diesel)
    Last Post: January 13th, 2009, 02:36 PM
  2. 03 lb7 duramax
    By mike37davis in forum Duramax LB7
    Last Post: January 9th, 2009, 02:16 PM
  3. Duramax timming
    By Rambo in forum Duramax LB7
    Last Post: April 7th, 2007, 07:23 PM
  4. Duramax Programming
    By GMPX in forum General (Diesel)
    Last Post: December 11th, 2005, 11:04 PM
