Results 1 to 10 of 10
Thread: dsp5 problem
    Mar 2007
    Default dsp5 problem
    hey guys i just installed the dsp5 switch on my truck, and i ran a full flash when i reprogramed the ecm, but when i press on the pedel except on 1 and 5 witch are stock tunes, it doesnt do anything, i can hear it idle a lil differnt but thats about it, any ideas?
    Might seem like a obvious question, but did you populate all the other tables in the DSP area's?
    Mar 2007
    u mean put a modify a tune into them? sorry im not very good at efi live yet
    Send your DSP5 tun file to support@efilive.com, I'll sort it out for you. Might take a day before it finds it's way to me.
    Mar 2007
    got it all worked out, thanks gmpx
    Oct 2008
    Quote Originally Posted by brandon04lb7 View Post
    What was the problem? I'm having issues also
    04 lb7
    Oct 2008
    Quote Originally Posted by dt.2448 View Post
    I didn't do a Full Flash. I got her now though
    Thanks to Nick (at 11pm on a sat night) thats customer service!
    04 lb7
    Jan 2009
    Default 03 lb7
    first off hello everyone...happy new year...my truck just recently started acting up...it will start just fine andrun for 10-12 seconds then die....will turn over but not fire for 5-10 min. checked diag. and no codes cames any info. would be greatly appreciated..thanks
    mike37davis, welcome and Happy New Year...
    Lifetime Member vortecfcar's Avatar
    Apr 2007
    Quote Originally Posted by mike37davis View Post
    Mike,
    Do you have EFILive? If so, you might try logging the truck as it runs and stalls to help diagnose the source of the stall. Usually something like this is fuel system related, possibly losing prime.
    Nick
    ps- next time, I'd recommend starting a new thread
  1. new to efi and dsp5
    By 516rider in forum Duramax LLY
    Last Post: January 26th, 2010, 12:24 PM
  2. Dsp5 lly help!
    By josh08 in forum Duramax LLY
    Last Post: December 6th, 2009, 02:33 PM
  3. DSP5 Problem?
    By Cougar281 in forum Duramax LLY
    Last Post: December 16th, 2008, 02:23 PM
  4. PID Problem w/BBB - Asked by Cougar 281 (FRPDES problem)
    By Jasondt2001 in forum FlashScan V2 BB Logging
    Last Post: March 23rd, 2008, 02:02 PM
