Results 1 to 4 of 4
Thread: Bench Harness?
    Aug 2008
    Default Bench Harness?
    Anyone know if there is a bench harness available for the P12? For sale that is...
    Might have to make break down and make one but I would rather purchase one...
    FLASHSCAN V2 & AUTOCAL
    Aug 2008
    I just read the Bench Harness Tutorial and it says that the E40 and the P12 have the same pinout...So that means I can use an E40 Bench Harness and it should work...
    Cool.....
    Correct, My bench harness with that style connector does 6 different ECM types.
    E40 (V8) , P05 (V6), P11 (4cyl), P12, LLY, E22 Northstar.
    I might have to make one here soon for the P10...only problem is there arent any other PCM/ECMs that use the same wiring harness. Oh well, Im just really mad GM has killed the I6 for good :(
  1. bench harness for ls2 and e38
    Last Post: March 29th, 2007, 12:39 PM
  2. LBZ/LLY Bench Harness
    By Dream8000 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 14th, 2007, 02:13 AM
  3. bench harness
    Last Post: June 15th, 2006, 04:09 AM
  4. Bench Harness
    By Biodiesel66 in forum Duramax LB7
    Last Post: May 3rd, 2006, 08:34 PM
  5. bench harness
    By madprof01 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 21st, 2005, 02:25 AM
