Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: RR Setup
    Mar 2007
    Default RR Setup
    I am working my way through the set up while I wait for my license. and I have struck a problem....When I go to device manager on my laptop there is no com port listed as in the instructions. I know it should be there but its not...any suggestions
    Mike
    Oct 2004
    Do you see a device appear under the Universal Serial Bus controllers section in Device Manager? You may also try using Native USB settings in the Tune Tool?
    If neither of those work for you I would:
    - Remove the existing installed drivers (using FTClean)
    - Connect RoadRunner and load it's driver (from 'C:\Program Files\EFILive\Drivers\RoadRunner')
    - Connect FlashScan and load it's driver (from 'C:\Program Files\EFILive\Drivers\EFILive')
    Andrew
    EFILive Crew
    Mar 2007
    Quote Originally Posted by Tordne View Post
    Thanks for the help.
    There is :universal serial Bus controllers: in Device Manager
    Mar 2007
    Look for a sticky thread in the RR Forum about installing the latest FTDI drivers.
    You using windows Vista? I just got mine working with this Vista laptop days ago.
    Let us know how it is going along.
    Eric
    Mar 2007
    Thanks Eric, I am using Windows XP
    Mar 2007
    So did you get it working? Updates please!
    Mar 2007
    Quote Originally Posted by Stealth97 View Post
    Not yet..........
    Mar 2007
    When I go to connect it says
    "no Roadrunner USB device can be found"
    Nov 2006
    is it licensed?
    see if this helps
    LC-1 WBO2
    Mar 2007
    Here is whats in device manager, what do I do from here??
  1. LC1 setup for e85 ?
    By yellowC6ohio in forum General (Petrol, Gas, Ethanol)
    Last Post: June 13th, 2008, 04:11 AM
  2. Need Help with E-fan setup....
    By MrZ71man in forum General (Petrol, Gas, Ethanol)
    Last Post: October 21st, 2007, 09:17 AM
  3. Pic of my setup.
    Last Post: September 13th, 2005, 09:45 AM
  4. What is the best way to setup PE VS RPM?
    By BowlingSS in forum General (Petrol, Gas, Ethanol)
    Last Post: August 2nd, 2005, 03:33 PM
  5. 2 bar map setup
    By AGRO in forum General (Petrol, Gas, Ethanol)
    Last Post: June 12th, 2005, 04:39 PM
