Nope, same thing
post a screen shot of the problem.
LC-1 WBO2
Hows this
how about the device manager too.
LC-1 WBO2
And also the RoadRunner tab of the properties in the Tune Tool.
Andrew
EFILive Crew
Here you go
It should not work as shown in those screenshots. As there is no 'Ports' section in the Device Manager screen the USB Serial is not actually being loaded as a COM port.
You could try changing the Properties to Native USB.
Incidentally, did you try uninstalling drivers using FTClean and loading in the order I recommended in the first post?
Andrew
EFILive Crew
