Results 1 to 3 of 3
Thread: Visibility to Active Tables/Variables in Scan Files
    May 2008
    Default Visibility to Active Tables/Variables in Scan Files
    Is there an easy way to trace what tables, multipliers, or other variables are active in a current value that's recorded in the scan tool? For example, there are many tables, multipliers, etc., that might affect spark timing or commanded fuel, for example. How can you identify the active parameters responsible for a commanded value at a moment in time? Thanks for the help!
    Bobby
    Oct 2004
    Not as easily as I expect you are hoping
    So there are a couple of way that this can be done (using spark as the example):
    1. Log a number of the spark PIDs which will then show you the retard or advance being included in the final spark fgure (i.e ECT/IAT, Burst Knock etc).
    2. By logging the PIDs used as axis in the modifier tables (often IAT, ECT etc) you can trace through the tables in the calibration to see which was the active cell, and therefore the underlying values.
    Hope that helps.
    Andrew
    EFILive Crew
    May 2008
    Thanks for the quick response. Well... I guess that keeps things from getting too easy & boring, then!
    Regards,
    Bobby
  1. Replies: 16
    Last Post: June 1st, 2010, 08:05 PM
  2. can't read scan files without sd card?
    By SS2win in forum FlashScan V2
    Last Post: June 22nd, 2009, 04:28 AM
  3. Any way to define variables in a custom PID?
    By thunder550 in forum General
    Last Post: June 15th, 2009, 03:46 AM
  4. error 0005 copying dtc files to scan folder
    By Brian1 in forum FlashScan V2
    Last Post: January 21st, 2009, 12:01 PM
  5. Can't open BB logging .efi files with latest scan tool
    By Neptune in forum Black Box Logging
    Last Post: May 22nd, 2008, 02:52 AM
