Page 3 of 12 FirstFirst 12345 ... LastLast
Results 21 to 30 of 119
Thread: RoadRunner guts kit?
  1. #21
    Jan 2007
    that's not a bad idea, did you use the "A" type or "B" type?
  2. #22
    Pretty sure it is a B barrel on the through hole/pass through, so I could get a short USB-A to B inside and a USB B to A outside.
    Where A is the narrow rectangular and the B is the more squarish connector.
  3. #23
    Jan 2007
    I ordered some RR headers, and I have already desolderd the flash chip from my spare 717 pcm, now I wait for the headers, I might just have to dig my car out of the snow to give this thing a try.
  4. #24
    Nov 2006
    Other than the "joy" of doing it yourself and saving $110, why not buy the pre-made RR?
    Have you tried to install the emulator in an E38,E40 ect.?
    IMO
    Skip the USB and use the Bluetooth.
    It`s expensive but is 1 less wire to use.
    You can probably make your own dongle for less.
    LC-1 WBO2
  5. #25
    Jan 2007
    Moates only offers the RR for the V8 cars and trucks, this will be going in a 2001 3.8L Grand Prix GTP. I dont think EFILive offers support for that vehicle either, only TC2 supports it. And it is no problem to work with electronics, I work with them everyday and the 44 pin chip is nothing compared to some componets that require a micorscope to solder.
  6. #26
    Jan 2007
    I just looked up the data sheet of my Intel chip, if you ahve a pcm that locks up while flashing, couldnt you just replace the Intel flash chip, or better yet remove it and replace it with a RR and still have a good pcm?
  7. #27
    EFILive and RR should work in any PCM we support that it can be squeezed in to, so that also means the 4cyl (LS1 style) PCM. But, I'm not sure it is actually enabled to work with it. I think some people actually got it working in the Allison TCM too.
    E40 uses a different flash chip than the LS1 style PCM, E38 is different again, plus the E38 CPU clock speed is 56MHz or something like that, I'm not sure the RR was ever designed to run that fast. But finally, the real estate issue on the E40 & E38.
  8. #28
    I thought you had said the RR license only worked on the 3 streams for the RR. So it WILL work on anything EFILive will support?
  9. #29
    Jan 2007
    EFILive doesnt support the Pontiac 3.8L does it? I didnt seee support on the list.
  10. #30
    Jan 2007
    Quote Originally Posted by N0DIH View Post
    If you have any problem, give me a scream, it worked well, soldering/unsoldering stuff like that is a piece of cake. But I have done it for years too.
    Remember, ESD protect things! You are on the bus, don't zap it!!!!
    Edit: Where are you located?
    does the RR have to be in the v6 pcm before it will take the v6 calibration file? I tried for fun to flash my RR on my old laptop with the v6 file and it wouldnt take it, I tried flashing in my 6.0 file and it worked.
  1. Guts Kit installation
    By SS2win in forum RoadRunner Real-Time PCM Emulator
    Last Post: March 6th, 2015, 12:41 AM
  2. RR 'Guts KIt' installation???
    By hquick in forum RoadRunner Real-Time PCM Emulator
    Last Post: October 7th, 2008, 12:29 PM
  3. Im making a tutorial for the Roadrunner guts kit install today.
    By wait4me in forum RoadRunner Real-Time PCM Emulator
    Last Post: October 5th, 2008, 04:33 PM
