Results 1 to 2 of 2
Thread: RR Lean cruise?
    Dec 2008
    Default RR Lean cruise?
    I'm new to tuning and I'm in the absorb information and get familiar with my stock tune before I change anything. I was thinking if you had a RR couldn't you just command A/F to say 15.1/1 or so after you set the cruise control? Wouldn't that be a fast simple Lean Cruise? Is there a way to automatically grab the cruise active signal and set a different A/F when it's enabled???
    Just wondering,
    Ed
    Oct 2006
    Quote Originally Posted by BRD-PREY View Post
    Just wondering,
    Ed
    Yep , sure can , with a Custom OS you can command AFR or EQ at certain loads and rpm , you can do it without a COS but the COS does a finer job .
    Some say you can play with O2 mv and gain some .
    When cruise is set at certain speeds the PCM will command a general AFR at that rpm and load , so you can target that area of the AFR Table with desired AFRs , just like lean cruise does , or do a .cax and enable LC .
    So I have heard .
    2006 Trailblazer
  1. can a lean idle or going lean during light cruise harm the engine?
    By ryans1000 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 3rd, 2009, 12:44 PM
  2. Lean Cruise and Cruise Control
    By neil in forum Tuning For Economy
    Last Post: July 9th, 2007, 08:42 PM
  3. Lean Cruise - US - LQ4 6.0L - Anyone done it?
    By Zfreak in forum General (Petrol, Gas, Ethanol)
    Last Post: January 18th, 2007, 10:58 AM
  4. how to set lean cruise
    By bifster in forum General (Petrol, Gas, Ethanol)
    Last Post: October 2nd, 2006, 07:20 AM
  5. lean cruise
    By 69camaro5speed in forum General (Petrol, Gas, Ethanol)
    Last Post: January 14th, 2006, 09:43 PM
