still saying invalid file.
I had to name it that but it was Options configuration settings before. It did not say Options.ini
2000 NBM trans am.
427 Dart ship block,Lme ported Ls7 heads 12.5 compression
246/262 .730/.712 112+4 low lash solid roller
Rmvb 4l80 with transbrake, 8" FTI converter
12 bolt Moser rear end with 4.10 gears
One more question , in the 98 pid list it shows in my options ini to have GM.CYLAIR_DMA
I am going to copy and paste my options for 98 ls1 and 99+ ls1=; __________________________________________________ _______________________
*PSL_98
;Node PIDs (pid1|pid2|...|pidn) Alarm (min:max:style:time*10ms:hold*sec)
PCM, ECT, -40:110:1:1:0
;PCM, FUELSYS
PCM, CYLAIR_M
PCM, DYNCYLAIR_M
PCM, IAT
PCM, LONGFT1
PCM, LONGFT2
PCM, EOPS
PCM, MAP
PCM, RPM, 0:6500:2:1:0
PCM, SPARKADV
PCM, TP
PCM, VSS
PCM, AFR
PCM, HO2S11
PCM, HO2S21
PCM, IBPW1
PCM, IBPW2
PCM, KR
PCM, MAFFREQ
-, WO2ST1
-, WO2ST2
-, WO2LAM1
-, WO2LAM2
-, WO2AFR1
-, WO2AFR2
*PSL_LS1
PCM, FUELSYS
PCM, IAT
PCM, LONGFT1
PCM, LONGFT2
PCM, EOPS
PCM, MAP
PCM, SPARKADV
PCM, TP
PCM, VSS
PCM, AFR
PCM, HO2S11
PCM, HO2S21
PCM, IBPW1
PCM, IBPW2
PCM, KR
PCM, MAFFREQ
-, WO2ST1
-, WO2ST2
-, WO2LAM1
-, WO2LAM2
-, WO2AFR1
-, WO2AFR2
2000 NBM trans am.
Now, Could I just log from the 98 pid list?
2000 NBM trans am.
; | Copyright © 1999-2007 |
; | EFILive Limited |
; | web: http://www.efilive.com |
; | email: info@efilive.com |
; |_________________________________________________ ______________________|
; Modifications
; Version | When | Who | Why
; 8.0 | 2007-Feb-16 | PSB | Created file
*PID_SELECTIONS
;PID selection list
; Cap1 and Cap2 form the "on-screen" display option from which the user may select.
; Controllers lists 1 or 2 "&" seperated pid memory map (*.pmm) files.
; PSL is the PID Selection defined later in this file
; PCU is the PID Custom Units defined later in this file
;Cap1 Cap2 Controllers (Engine&Trans) PSL PCU
LS1 98, Manual, LS1A_M.pmm, PSL_98, PCU
LS1 98, Auto, LS1A_A.pmm, PSL_98, PCU
LS1 99+, Manual, LS1B_M.pmm, PSL_LS1, PCU
LS1 99+, Auto, LS1B_A.pmm, PSL_LS1, PCU
P10, Manual, P10_M.pmm, PSL_LS1, PCU
P10, Auto, P10_A.pmm, PSL_LS1, PCU
P12, Manual, P12_M.pmm, PSL_LS1, PCU
P12, Manual, P12_A.pmm, PSL_LS1, PCU
E40, Manual, E40.pmm, PSL_LS2, PCU
E40, Auto, E40.pmm&T42.pmm, PSL_LS2, PCU
E38, Manual, E38.pmm, PSL_LS2, PCU
E38, Auto, E38.pmm&T43.pmm, PSL_LS2, PCU
E67, Manual, E67.pmm, PSL_LS2, PCU
E67, Auto, E67.pmm&T43.pmm, PSL_LS2, PCU
LB7, Manual, LB7.pmm, PSL_LB7, PCU
LB7, Auto, LB7.pmm&AL5.pmm, PSL_LB7, PCU
LLY, Manual, LLY.pmm, PSL_LB7, PCU
LLY, Auto, LLY.pmm&AL5.pmm, PSL_LB7, PCU
LBZ, Manual, LBZ.pmm, PSL_LBZ, PCU
LBZ, Auto, LBZ.pmm&AL5.pmm, PSL_LBZ, PCU
LMM, Manual, LMM.pmm, PSL_LBZ, PCU
LMM, Auto, LMM.pmm&AL5.pmm, PSL_LBZ, PCU
; PID Selection List
; Node: Is one of PCM, ECM or TCM (use "-" for external PIDs).
; PCM = Powertran controller, engine and trans combined into one controller.
; ECM = Dedicated engine controller only.
; TCM = Dedicated transmission controller only.
; If you are unsure whether to use ECM or PCM, use PCM. PCM will match both ECM and PCM.
; The Node specified from which controller the PID will be retrieved.
; i.e. ECM-RPM v's TCM-RPM.
; PIDs: Is one or more "|" seperated PID names. The first valid PID will be used.
; Alarm: Is 5 ":" seperated fields:
; min: Minimum value, below which the alarm will sound.
; max: Maximum value, above which the alarm will sound.
; style: Is one of:
; 0 = No sound, No LEDs
; 1 = Low pitch
; 2 = Medium Pitch
; 3 = High Pitch
; 4 = Very high Pitch
; 16 = Illuminate LED 1
; 32 = Illuminate LED 2
; 48 = Illuminate LED 3
; 64 = Illuminate LED 4
; 128 = Illuminate LED 5
; Add Pitch and LED values together to enable audio and visual alarms.
; For example, for Medium Pitch and LED 4, use 2+64 = 66
; time: Time (in 10ms increments) for which alarm will be sounded.
; hold: Time (in seconds) for which the displayed value will be frozen (not implemented yet).
*PSL_98
;PCM, FUELSYS
PCM, CYLAIR_M
PCM, DYNCYLAIR_M
PCM, IAT
PCM, LONGFT1
PCM, LONGFT2
PCM, EOPS
PCM, MAP
PCM, SPARKADV
PCM, TP
PCM, VSS
PCM, AFR
PCM, HO2S11
PCM, HO2S21
PCM, IBPW1
PCM, IBPW2
PCM, KR
PCM, MAFFREQ
-, WO2ST1
-, WO2ST2
-, WO2LAM1
-, WO2LAM2
-, WO2AFR1
-, WO2AFR2
*PSL_LS1
PCM, FUELSYS
PCM, IAT
PCM, LONGFT1
PCM, LONGFT2
PCM, EOPS
PCM, MAP
PCM, SPARKADV
PCM, TP
PCM, VSS
PCM, AFR
PCM, HO2S11
PCM, HO2S21
PCM, IBPW1
PCM, IBPW2
PCM, KR
PCM, MAFFREQ
-, WO2ST1
-, WO2ST2
-, WO2LAM1
-, WO2LAM2
-, WO2AFR1
-, WO2AFR2
*PSL_LS2
ECM, ECT, -40:110:1:1:0
ECM, FUELSYS
ECM, IAT
ECM, LONGFT1
ECM, LONGFT2
ECM, MAP
ECM, RPM, 0:6500:2:1:0
ECM, SPARKADV
ECM, TP
ECM, VSS
ECM, AFR_B|AFRATIO_M
ECM, HO2S11
ECM, HO2S21
ECM, INJPWB1
ECM, INJPWB2
ECM, KNKRET
-, WO2ST1
-, WO2ST2
-, WO2LAM1
-, WO2LAM2
-, WO2AFR1
-, WO2AFR2
; T42 4/5 speed
TCM, TFT
TCM, TIS
TCM, TOS
TCM, TCCSLIP
TCM, GEAR
*PSL_LB7
PCM, TP
PCM, ECT
PCM, IAT
PCM, MAF
PCM, RPM
PCM, VSS
PCM, BARO2
PCM, BOOST_M
PCM, FRPACT
PCM, FRPDES
PCM, FUELQ_MAIN_M
PCM, MAINBPW
PCM, MNINJTIM
PCM, PIINJTIM
PCM, PILOTRATE
; Allison 5 speed
TCM, TFT
TCM, TIS
TCM, TOS
TCM, TCCSLIP
TCM, GEAR
TCM, TRQENG_B
*PSL_LBZ
ECM, BARO
ECM, ECT
ECM, FRP_C
ECM, IAT
ECM, MAF
ECM, MAP
ECM, RPM
ECM, VSS
ECM, FRPDES
ECM, MAIN1Q_M
ECM, MAIN1T_M
ECM, MNINJTIM
ECM, PILOT1Q_M
ECM, PILOT1T_M
ECM, TCVPOS
; Allison 6 speed
TCM, TFT
TCM, TIS
TCM, TOS
TCM, TCCSLIP
TCM, GEAR
TCM, TRQENG_B
; PID Custom Units
; PCU specifies the controller and PID for which to define a custom unit
; Caption is the caption displayed on screen during BB logging (8 characters maximum).
; Prec is the number of decimal places to display
; Units is the display units name.
; Op is the operator, one of:
; * = multiply
; / = divide
; i = invert_then_multiply
; The metric value of the PID is multiplied, divided or inverted then multiplied by Factor.
; Offset is then added.
*PCU
; PID Caption Prec Units Op Factor Offset
PCM,ECT, Coolant, 0,°F, *, 1.8, 32.0
PCM,MAP, M'Fold, 1,psi, /, 6.894757,
PCM,VSS, Speed, 0,mph, /, 1.609344,
PCM,SPARKADV,Spark
PCM,IAT, Intake, 0,°F, *, 1.8, 32.0
PCM,MAF, AirFlow, 1,lb/m, /, 7.559873,
PCM,TP, Throttle
PCM,KR, Knock
-, T1, T1, 1,°F, *, 1.8, 32.0
-, T2, T2, 1,°F, *, 1.8, 32.0
THis is my full options.ini I am going to check back later and did not want to not have the right thing posted. Thanks for any help guy's
2000 NBM trans am.
I would just replace the EOPS pid with the CYLAIR_M pid & go from there.
The Tremor at AIR
2000 NBM trans am.
