Results 1 to 3 of 3
Thread: Inline-6 Conversion ??
    Oct 2005
    Default Inline-6 Conversion ??
    I am considering to put a fuel injection on an older Chevy inline-6 engine (292 cui.) coupled to a 4L60E.
    What engine sensors do I need?
    TPS
    IAT
    MAP
    ECT
    Crank Position
    Cam Position
    Knock?!
    2x O2
    Actuators:
    6 Injectors? Would 3 work if properly sized? -> siamesed intake
    IAC
    Ingnition (with Distributor >> want it to look stock)
    I was thinking about using an LS1B OS from a 4.3L V6 (2003).
    Am I missing something?
    2005 RCSB 2500HD GMC Sierra DURAMAX LLY
    1955 Chevy Truck 1st series, being restored
    2002 Mercedes C270 CDI
    Jan 2007
    Only thing I can think of is a VSS....but that will be located in the 60E.
    Running a MAF?
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Oct 2005
    I was going to run it SD with semi-CL. Adding a MAF would be difficult, as I plan on running it with a 4-71 blower and a throttle just above.
    As far as injector placement I am a little confused as I have seen them installed above the blower, underneath or in the intake runners. I was going to place them in the runners as this is the most logical place for me to get a fast response when running CL.
  1. Please help with LS2 conversion
    By jasonsfbodies in forum Gen IV V8 Specific
    Last Post: August 3rd, 2010, 01:42 AM
  2. 4 cyl inline chev..
    By Shift2late in forum General
    Last Post: December 15th, 2009, 11:11 AM
  3. vz ls1 to l98 conversion
    By shane in forum Gen III V8 Specific
    Last Post: November 30th, 2008, 11:41 PM
  4. Vortec 4.2L Inline 6-cylinder no connecto
    Last Post: August 3rd, 2008, 01:04 AM
  5. E-85 Conversion
    By vatman02 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 26th, 2008, 02:53 AM
