Results 1 to 5 of 5
Thread: Alarms when logging from V2
    Feb 2008
    Default Alarms when logging from V2
    When I setup an alarm for instance ECT:
    Does the value I put in have to be in *C or *F?
    If I press enter on the V2 and view data in *F, will the alarm switch to read *F or still *C temps.
    12 Second LMM
    It has to be in metric units °C...
    pressing ENTER (to display imperial units °F) only changes the display... the alarm will still work correctly as it is based on metric units.
    Feb 2008
    Thanks. I was in the middle of testing, but you responded before I finished, lol.
    Heres another,
    I selected to light 1st LED and sound mid tone, (i added the numbers together) but all I get is the tone, no light. I then tried another LED and a higher pitch, and it only toned for the time I setup, then wouldnt do it again until I reconnected?
    12 Second LMM
    There is an option in the V2 setup options for LED Mode...
    LED Mode is "status" by default, you have to set it to "alarm" (or something).
    Feb 2008
    Man your on Fire tonight, lol.
    Thanks.
    12 Second LMM
  1. Audible alarms
    By Blacky in forum FlashScan V2 BB Logging
    Last Post: December 28th, 2007, 07:35 AM
  2. Logging RPM
    By oztracktuning in forum Black Box Logging
    Last Post: January 20th, 2006, 05:55 PM
  3. I have a few Q's about logging.
    By SmaknSS in forum General
    Last Post: December 1st, 2005, 05:33 AM
