Is that bad?
Is that bad?
E85 is NOT flex fuel.
2003 Chevy S10 4.3L LU3 LS1B Auto
48 LB injectors
Race Proven Motors 2114 intake
T70 turbo.
No, not at all...If I buy that from you all i would need is a 411 pcm
FLASHSCAN V2 & AUTOCAL
S10Warehouse generally keeps a pretty good supply of them:
http://cgi.ebay.com/ebaymotors/v6-4-...mZ370131432461
48 LB injectors
T70 turbo.
you shouldn't need a whole wiring harness. just the PCM, the connectors, and a couple of pins for the couple of splices that need to be done. otherwise its just simply moving pins from the 98 PCM connectors to the 411 connectors. unless the s10 vortec setups are way different than the full size trucks, but I wouldn't think they are.
http://www.pacificp.com/forum/viewtopic.php?t=3240
Yes, linking is checked
I uploaded a stock tune file and a data log. Maybe it'll work on some one else's computer...-Especially-The spark linking from scan tool to tuning tool...
Anyone got 2-3 minutes, to try this.....
Maybe it's something I'm doing/or did wrong
That's weird. I wonder if the Vortec controller doesn't use a VIN, so efilive doesn't know how to correlate the tune with the scan. This doesn't seem to make since since the information message box just said it isn't a problem, just a warning.
48 LB injectors
T70 turbo.
I loaded your log/tune files...
The the vin is mismatched between the log and the tune... I am not sure if this matters.
I could not get linking to occur... I looked thru various tables in the tune and none of them say "Link:" next to the pid name on the axes of the tables...
to be able to link, the pid names must say "Link:" in front of them when you look at the table axis pids... I think this is why you're not linking.
Look at this file: C:\Program Files\EFILive\V7.5\Configuration\cal_link.txt
it defines the link pids... you may be able to edit in the tables/pids you want linked... make sure you use the same pid names as shown in the scantool PIDs tab.
Also, unrelated to linking, you're logging 25 channels... you may want to delete one pid to get down to 24 or less channels (delete BARO or LOAD) to get update rate up to 10 samples/second (instead of 5).
