Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 36
Thread: Anyone have a 4.3 Vortec V6?
  1. #21
    Aug 2008
    Nevinsb,
    Thats what I was thinking about the VIN# mismatch...
    Joecar,
    Yeah I'm usually down to 24 pids or less, I don't know why I logged 25 pids on that log....I'll look at the C:\Program Files\EFILive\V7.5\Configuration\cal_link.txt to make sure "Link:" is front of the Pid names...
    Also, when I do a read flash of the controller, it shows the Vin# in the Tune file(where it's suppose to be) but when I save it and open it back up, the Vin# is shown as NA...
    FLASHSCAN V2 & AUTOCAL
  2. #22
    Try writing the VIN using the scantool.
  3. #23
    Aug 2008
    I tried it already, and i was going to try it using DVT but the controller doesn't support it...
  4. #24
    Aug 2008
    Joecar,
    I'll check on the "Link:" part in a little bit and see what's up...
  5. #25
    Feb 2006
    There is no reference to "vortec" controllers in the cal_link file. If you open another tun file ie. LS1 car, it will link to the log file, even with the incorrect VIN. I have tried several variations of Vortec to attempt to get it to link, so far no good.
    Al
  6. #26
    Aug 2008
    Quote Originally Posted by ChipsByAl View Post
    Al
    That's what has me confused...
  7. #27
    Aug 2008
    Default Vortec Controllers "SUCK"
    I give up on this Vortec "CRAP"...I tried everything
  8. #28
    May 2008
    At least it isn't the 97 Vortec controller.
    2003 Chevy S10 4.3L LU3 LS1B Auto
    48 LB injectors
    Race Proven Motors 2114 intake
    T70 turbo.
  9. #29
    Feb 2006
    Since there is no reference to the Vortec in the cal_link.txt file, maybe Paul or Ross has to add something in the Tune tool progam to make it work. Or just what is the exact name to add in the cal_link.txt file to get it to link.
    Al
  10. #30
    The section names in the cal_link file need to be the same as the folder names in the Program Files\EFILive\V7.5\Calibrations folder.
    So for vortec, you'd put the link definitions under a section name of [VRB]
  1. vortec 4.3
    By 770johnnyw in forum Vortec V6/V8 Specific
    Last Post: April 11th, 2010, 03:55 AM
  2. vortec v6 to vortec v8 swap
    By grezzmky in forum Vortec V6/V8 Specific
    Last Post: September 21st, 2009, 06:49 AM
  3. 08 Vortec Max cng
    By 05lly in forum E37, E38 & E67 PFI ECM's
    Last Post: June 23rd, 2008, 10:29 AM
  4. 96/97 vortec
    By 69camaro5speed in forum General
    Last Post: January 1st, 2008, 06:01 PM
  5. 96-98 Vortec 5.7
    By Buzzard in forum Vortec V6/V8 Specific
    Last Post: May 24th, 2007, 11:31 AM
