Page 4 of 4 FirstFirst ... 234
Results 31 to 36 of 36
Thread: Anyone have a 4.3 Vortec V6?
  1. #31
    Aug 2008
    Ok,
    So, since there isn't a Vortec cal_link...I pretty much need to make my own...No wonder I couldn't find it...
    Gotcha...
    Thanks Blacky,
    Oops I mean Paul
    FLASHSCAN V2 & AUTOCAL
  2. #32
    Feb 2006
    Blacky I tried using [VRB] at the beginning of the section again with a simple VE Table link and still it doesn't work. The [LS1] section doesn't have a [LS1A] or [LS1B] identifier to lead it as the Calibration folder shows. There must be something else to it. This is what I had tried to use. I put this text before and after the LS1 section.
    Al
    [VRB]
    ;Main VE Table
    B0101.ROW=SAE.RPM
    B0101.COL=SAE.MAP
  3. #33
    Aug 2008
    Quote Originally Posted by ChipsByAl View Post
    Al
    [VRB]
    ;Main VE Table
    B0101.ROW=SAE.RPM
    B0101.COL=SAE.MAP
    This is what I tried, No Luck though...
    [VRB]
    ;///// Engine Calibration: Spark: General \\\\\
    ;Main Spark Advance
    B5913.ROW=SAE.MAP
    B5913.COL=SAE.RPM
    ;///// Engine Calibration: Fuel: Airflow \\\\\
    ;Main VE Table
    B0101.ROW=SAE.RPM
    B0101.COL=SAE.MAP
    ;Backup VE Table
    B0103.ROW=SAE.RPM
    B0103.COL=SAE.MAP
  4. #34
    Sorry, ignore my comment about the folder names matching the section names. That was wrong.
    For some reason the [VRB] section should be called [L31]
    Here's the full list:
    Code:
    Folder Section
    Name   Name
    LS1A   [LS1]
    LS1B   [LS1]
    ALLA   [ALI]
    ALLB   [AL6]
    LB7    [DMX]
    LLY    [DMX]
    E40    [E40]
    E38    [E38]
    E67    [E67]
    T42    [T42]
    T43    [T43]
    L52    [L52]
    LL8    [LL8]
    E35    [LBZ]
    E35    [LMM]
    VRB    [L31]
    V6     [P05]
    4CYL   [4CY]
  5. #35
    Aug 2008
    Default Beautiful....!!!!!
    Thanks Paul,
    It's working perfectly...
  6. #36
    Feb 2006
    Thanks times 2. Appreciate the list for the others too.
    Al
  1. vortec 4.3
    By 770johnnyw in forum Vortec V6/V8 Specific
    Last Post: April 11th, 2010, 03:55 AM
  2. vortec v6 to vortec v8 swap
    By grezzmky in forum Vortec V6/V8 Specific
    Last Post: September 21st, 2009, 06:49 AM
  3. 08 Vortec Max cng
    By 05lly in forum E37, E38 & E67 PFI ECM's
    Last Post: June 23rd, 2008, 10:29 AM
  4. 96/97 vortec
    By 69camaro5speed in forum General
    Last Post: January 1st, 2008, 06:01 PM
  5. 96-98 Vortec 5.7
    By Buzzard in forum Vortec V6/V8 Specific
    Last Post: May 24th, 2007, 11:31 AM
