Results 1 to 10 of 14
Thread: error 0005 copying dtc files to scan folder
    Apr 2008
    Default error 0005 copying dtc files to scan folder
    Just got my spalsh screen loaded thanks to Cindy over from Dieselplace.com fourms. Had to format the config file. Also copied all *.ppm files in config while there. So I then started reading about loading the a,b,c,d dtcs files under the scan folder. I select them and copy and paste. Well again I get error 0005 and select properties gets me error 0026 and refresh error 0182. Same 0005 error when trying to install a splash screen but formatting the config file fixed that.
    So issue now is getting the dtc files over to scan folder. I did reformat the config file and treid again but same errors and then reloaded the other ppm files and new splash screen back for now.
    edit:
    Since loading the ppm files i can now load pids for logging. Have to try logging tomorrow. Was told it can be done but but could not file options.txt file. Now that it is there I am set for standalone logging. Just need to get the dtc files over to the scanfolder now.
    edit:
    bootblock 2.06.02
    firmware 2.06.06
    Thanks for your time and help.
    Brian
    Brian,
    Don't do copy/paste... instead do drag/drop from upper pane (folder) to lower pane (Config tab).
    Apr 2008
    Ok I copied a,b,c,d dtc file to the config tab. So next code I get will give it a try to see if it tells me what it is. Had to remove some of the ppm files to get the dtc files copied. Must be a space limit on the EFILive V2 for items like this. Figure there would be enough room for all that and more. I did look at the scan tab after loading the dtc files but see nothing and still get errors when hitting refresh and properties like mentioned above . Is this normal. Have another post like so on
    http://www.dieselplace.com/forum/sho...63#post3083863
    Thanks for the help JoeCar.
    Brian
    You only need the .pmm files for the ECM/TCM that you want to log from.
    Yes, there is a space limit.
    Also, did you do a Format on the Config tab prior to copying the .pmm and Options.txt files...?
    At some point, did you do a Format on the SD card and/or the internal flash log space...?
    Oh... drag the .dtc files to the Scan tab.
    Post some screenshots when this happens.
    Quote Originally Posted by Brian1 View Post
    As Joe said, the dtc files should be dragged into the [Scan] tab page, not the [Config] tab page.
    The [Config] tab page has limited space and is only for Options.txt and the *.pmm files.
    To check the space used/available in the [Config] tab page click on the [Properties] button in the [Config] tab page.
    To check the space used/available in the [Scan] tab page click on the [Properties] button in the [Scan] tab page. (it can take a while if you have a large SD card in use).
    We are working on the V8 software which has a user friendly front end program that handles all this file copying and Config/Scan file systems for you. Sorry that you have to "know" this stuff right now, but the software is not quite ready yet.
    Apr 2008
    Ok I got it all done now. turns out the sdcard I was using is bad. Would not format on the V2. Popped in another one I had and formatted and then copied the dtc files to the scan tab. Now they show up in the scan tab. Then went and reformatted the flash memory, load all pmm files to config and install my custom splash screen.
    I guess the last thing to do is load tunes and install tunes from the v2 sdcard as standalone once you guys get all the bugs worked out.
    Thanks to everyone that help.
    Brian
    Brian, you should be able to do BBL logging.
    Nov 2006
    I have just tried to drag them to the scan tab and i get ERROR $0402
    I also get the same error when clicking properties and refresh.
    I never copied the DTC files before.
    LC-1 WBO2
    Quote Originally Posted by mr.prick View Post
    $0402 SD card not present
    shoemike, are you sure your SD card is plugged in correctly (making good contact)...?
    Nov 2006
    must you use an SD card for that?
    i was using the internal memory.
    with SD card i get ERROR $0005
    after copying the DTCs to the SD card, i get ERROR $0183
    LC-1 WBO2
  1. Error: $0183 "Invaild Folder"
    By 8100 Power in forum FlashScan V2
    Last Post: January 3rd, 2010, 02:47 PM
  2. Error: $0183: Invalid Folder.
    By kwhiteside in forum Black Box Logging
    Last Post: October 19th, 2009, 02:34 PM
  3. Error: $0183 Invalid Folder
    By Tre-Cool in forum Black Box Logging
    Last Post: August 1st, 2009, 08:47 AM
  4. can't read scan files without sd card?
    By SS2win in forum FlashScan V2
    Last Post: June 22nd, 2009, 04:28 AM
  5. Error $0185 when copying files
    By Blacky in forum FlashScan V2 BB Logging
    Last Post: December 31st, 2007, 06:19 AM
