Results 1 to 4 of 4
Thread: Oil Temp Acceptable Range
    May 2008
    Default Oil Temp Acceptable Range
    What is an acceptable oil temperature range for an LSx 455 with 7.5 PSI supercharger? I'm running 220-230 degrees crusing and 250 if I drive aggressively for a period of time. Not sure if that is too hot or ok.
    Thanks,
    Bobby
    20F-30F above coolant temp is considered good.
    For hard driving, 250F is still considered within acceptable range.
    What oil are you using...?
    May 2008
    40W Valvoline Racing Oil
    Lifetime Member Bruce Melton's Avatar
    Oct 2003
    Mobil 1 is fine in those ranges and probably most full synthetics.
    The Corvettes throw a warning @ ~290.
    PowrMax Performance
    100 mm PowrMAF
  1. how much knock is acceptable
    By ryans1000 in forum Gen III V8 Specific
    Last Post: November 14th, 2009, 05:46 PM
  2. LTFT - range vs + range lean rich question
    Last Post: September 14th, 2009, 06:18 AM
  3. Does this afr reading seem acceptable?
    By azzhauler in forum General (Petrol, Gas, Ethanol)
    Last Post: May 13th, 2009, 06:34 AM
  4. afr thru out rev range...
    By brokenfly in forum General (Petrol, Gas, Ethanol)
    Last Post: May 22nd, 2007, 01:56 PM
