I had to format my laptop and start over with efi, I must not have something right. When doing auto ve process on a ls1, with my commanded fuel 14.68 part throttle and 12.8 WOT my bens are not matching correctly. I can look at commanded vs actual and see a ben of 1.0 which would tell me the fuel is correct, then check the actual and it may be 15 something. Then at WOT its the opposite, if I get a actual of say 13.1 which is leaner than commanded the bin will be like .95 which takes more fuel out. Does this make sense? I drove for a while and flashed the car a few times and had almost all 1.0's and checked the actual a/f and its still all over the place. I must have something configured wrong on my laptop. Im using a LM1 through serial cable on a V2 with the latest updates.
