the parameters that I need to change for a lope idle would be main injection pulse right?
Four stroke diesel S.S.B.B. Suck Squeez Bang Blow
06 LBZ with 5 inch magnaflow exhaust,Bd exhaust manifold, Bully dog outlook, Egr blocker, Firestone air bag system,Custom sound system, dual fuel filters,leveling kit, B&M deep tranny pan,TTS lift pump,Turbo Resonator plugged,Cooper ST 265/75R16, Bully nerf bars and B&W guardian headache rack sprayed with reflex bed liner, B&W turn over ball,B&W Tow&Stow, transgo jr, efi live Tuned By IdahoRob,tranny filled with transynd
WWW.ATPTrucks.COM
No.
Idle adjustments are in the Idle folder.
LC-1 WBO2
I am trying to get it to sound like it has a built cam in it. like this http://www.youtube.com/watch?v=JZ-FPTqBB2M
WWW.ATPTrucks.COM
lower the idle RPM.
LC-1 WBO2
Check out a couple of the duramax diesel forums. It's been discussed many times there.
actually its in the throttle base injection quanity. bump the box at 600rpms at 0 up to about 35
I have tryed the other forums and the others cant get it to work.
WWW.ATPTrucks.COM
The tables for the LBZ do not include throttle base injection, and there is no Idle folder for idle adjustments...any other suggestions guys?
