just wondering which model walbro pump fits vy model monaro? Also interested to know about other models as well.
as jezzab said good for 500hp
330 rwkw EFILIVE OS 01290005 SD Cam / Head Tuned 6 speed VY SS Commodore
10/71 Blown 572 Big Block Chev HQ 2 Door Monaro
GM Performance Centre
Busselton WA
AUSTRALIA
Phone: 0447 003050
Cheers, thanks for that info.
Make sure you modify the can that the pump sits in by drilling more holes in the bottom. Otherwise you may have the problem some people do (Me being one) of it draining the can empty before anymore fuel enters it.
I used a 3/8inch drill bit and put about 15 more holes in it.
My 2c.
I'll be looking into one of these next time I need a new pump.
http://www.racetronix.com/RX-F99-FPKG-2.html
Howard
DUCT TAPE.
98 K1500 'HOLDEN' Suburban.
The only problem I have had with the Racetronix pump was the plastic tube blowing off and cracking after I tightened it down more. It's nice that they actually added the venturi fitting though.
E85 is NOT flex fuel.
2003 Chevy S10 4.3L LU3 LS1B Auto
48 LB injectors
Race Proven Motors 2114 intake
T70 turbo.
