Results 1 to 4 of 4
Thread: High RPM upon startup
    Senior Member Naf's Avatar
    Aug 2006
    Default High RPM upon startup
    Ok, i have the followin setup
    6.0 SSR intake manifold
    BBK ported to 80.. tb
    JBA headers
    AEM intake
    1.7 Yella terra
    LS6 heads
    LS6 Cam
    5.3 LM7 lower block
    LS7 lifters
    7.4" pushrods
    LS2 injectors
    Full Escalade exhaust system
    I am tryin to tune the car which is provin difficult, but thats not the issue here, whenever i start up the vehicle cold or hot the rpm jumps up to 1500 then drops.
    I tried lowerin the VE @ 400 and 800 but still, high RPM
    I noticed that my afr at start up is 13.5 plus or minus a little.
    Please help me fix this...I dont like the high rpm...
    American Muscle, European Design, Japanese Tactics
    Feb 2006
    Post your current tun file and a start up log. That helps.
    Al
    Aug 2006
    I am sorry, but i cant seem to find my start up log, and believe it or not, but the car isnt jumpin to 1500 any more, and my EFI is actin up durin that as well...
    Devine issues, let me keep tryin, i lowered the timin and decreased the VE a bit more.
    Will keep you posted
    Mar 2005
    Hi there,
    go to "idle stepper motor parked" under idle control. This sets the idle motor position at key on and hence the amount of flare you get when you start the engine. Change it by around 1g/s amounts at a time to see a noticible result. Too easy
    Mike
    Quote Originally Posted by Naf View Post
    JBA headers
    AEM intake
    1.7 Yella terra
    LS6 heads
    LS6 Cam
    5.3 LM7 lower block
    LS7 lifters
    7.4" pushrods
    LS2 injectors
    "Just a tune > yeah right !!!! "
  1. Help with startup....
    By 01Blackerado in forum Gen III V8 Specific
    Last Post: December 14th, 2007, 11:31 AM
  2. LS2/7 ETC TB startup
    By Bruce Melton in forum General (Petrol, Gas, Ethanol)
    Last Post: December 14th, 2007, 01:39 AM
  3. Help On Initial Startup
    By Dale in forum General (Petrol, Gas, Ethanol)
    Last Post: November 10th, 2007, 08:08 AM
  4. Startup Airflow and Startup Friction Airflow whats the difference
    By carneb in forum General (Petrol, Gas, Ethanol)
    Last Post: July 31st, 2006, 08:59 AM
  5. Pinging on startup
    By oztracktuning in forum General (Petrol, Gas, Ethanol)
    Last Post: April 7th, 2006, 10:39 PM
