I'm a new user of Scan&Tune V2. One of the main reasons I chose it is its support for stand-alone operation. I understand that the ability to standalone program is coming soon in conjunction with the release of the AutoCal product.
It's not clear from the docs whether standalone reading of an ECM's tune into V2 memory is currently supported. I'm assuming it is but before I attempt this I would like to verify what is involved.
I've attached the V2 to EFILive and verified the drivers and licensing is in order. EFILive shows two open licenses. I'm assuming reading a tune from an ECM doesn't require any pre-setup such as logging does.
I'm assuming once the tune has been loaded in V2 memory there is a way for EFILive to extract it and store it on disk but I don't see any documentation of this. I also don't see an docs about how the data on the SD card is access via EFILive or how you use the SD card from the V2.
It might be useful to document more about how the V2 is used in standalone mode. All the docs I saw (with the exception of the fault code reading example in the quick start manual) assume the V2 is being used in the mode where its controlled by the PC.
