Results 1 to 10 of 14
Thread: 96-02 vortec intake solution
    Member CC&M's Avatar
    Dec 2008
    Default 96-02 vortec intake solution
    I have been working on an intake solution for the vortec and port fuel retrofit for early small blocks. This is going to include the manifold, TB adapter, fuel line adapter, and rails. I can also build to order a retrofit harness for the early engine conversion to the 0411 pcm. Dyno testing has proven this is more powerful than either the stock or marine intake. Drop me a PM if interested as I will build them as needed.
    Wade
    Aug 2008
    Any Pics???
    FLASHSCAN V2 & AUTOCAL
    Dec 2008
    Here is one installed on my K10 with a 4.9L caddy throttle body and MAF. That's part of another project to be discussed later.
    Dec 2008
    One more try to get the picture posted.
    Dec 2008
    Here is one that I have finished that wanted to pose for a pic.
    Lifetime Member schwoch1's Avatar
    Jan 2009
    Can't you use the boat Vortec intake and get the same end result?
    Looks like a nice piece!!!
    Mike
    Dec 2008
    I'm sure the boat intake has it's value, but I couldn't get mine to run good past about 5000. I'm using one of these that pulls till it hits the fuel cut off at 6200. I'm going to have to get one onto a test engine to verify the numbers though. I personally like the look of this over the OEM anyway. I use a TB that has the bottom ridge bored out and the air vane removed from the butterfly as well. I do them right here in my shop if anybody else wants theirs done.
    Wade
    Aug 2008
    Quote Originally Posted by CC&M View Post
    Good looking Intake....
    Jan 2009
    Wade
    I can see where the Boat intake would be restrictive in the upper RPM range, I suppose that boats are designed to run at idle or 4k RPM all day, no problems like that with your single plane design.
    Again, I commend you for putting effort into an engine that missed the boat on aftermarket support (except for it's heads)!!!!
    Mike
    May 2008
    Hi Schwoch1! I'll say "Welcome to the Forum" for JoeCar since he seems to be slacking.
    BTW, if you are ever in the Eagle area, please stop by.
    I bet that intake does flow better at high RPMs.
    2003 Chevy S10 4.3L LU3 LS1B Auto
    48 LB injectors
    Race Proven Motors 2114 intake
    T70 turbo.
  1. Update and solution to 98 PCM connection problem
    By eurospec1 in forum FlashScan V2
    Last Post: December 20th, 2007, 11:45 AM
  2. how long until an e67 custom os solution?
    By SScarTuning in forum E37, E38 & E67 PFI ECM's
    Last Post: November 13th, 2007, 06:22 AM
  3. COS3 cold lean startup solution
    By Whippled 496 in forum Custom Operating Systems
    Last Post: January 28th, 2007, 06:50 AM
  4. Temporary IAT Sensor Solution to 5 Wire MAF
    By S10Wildside in forum General (Petrol, Gas, Ethanol)
    Last Post: October 8th, 2006, 01:29 PM
