Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: A little help with a question
    Mar 2007
    Default A little help with a question
    I just got RR working and it is up dating VE table, But wont stop richening it up ,Scan tool is getting correct A/F reading and everything seems to work apart from that.....What am I missing??
    Mike
    Oct 2006
    Quote Originally Posted by Harrismarine View Post
    Mike
    What BEN pid are you using?
    The Tremor at AIR
    Mar 2007
    TecEdge...
    Oct 2006
    Have you verified the wideband AFR in the scantool is the same as showing on the unit?
    Do you have a log of this occuring you can post?
    The Tremor at AIR
    Nov 2006
    1. Make sure your WBO2 is configured and working properly.
    2. Make sure the proper PIDS are selected/configured properly and the cal.link.txt is configured properly.
    3. Make sure your WBO2 is in sync with the scan.exe.
    4. Configure your filter set(s) in the Roadrunner control panel.
    5. Set the update frequency and the course/fine settings to your desired amount.
    6. Set the RTACS min/max limit and the update accuracy in the RTACS tab.
    The update accuracy should be 0%.
    Note: RTACS only work while recording.
    pause recording to stop RTACS until recording is resumed.
    LC-1 WBO2
    Mar 2007
    After a few PMs from mr prick (Thanks by the way) It seems I have things working as they should BUT.. When the RR is up dating a cell in the VE table (which you can see happening) it is going the wrong way, The tune is a bit rich at idle which is backed up by the ben's in the scan map (showing .94 etc) But it keeps increasing the number in the VE (automatically) making the cell its on go way rich
    The scan tool map is correct as I can copy and paste as normal and it corrects the cells and tunes the map.
    RR is connecting and changing cells but it seems to be not referencing from the scan tool (which is working correctly), It must be a setting That I am missing or something I have not done correctly..What would cause this?????
    Member VT LS1 NZ's Avatar
    Make sure that in your RR Filters that the Pid you have selected is a Ben pid for your wideband and not the AFR pid of your wideband.And check your cal_link.txt file also for the correct pid.
    856RWHP 408 Supercharged LS1 Holden Commodore.
    Mar 2007
    I have been back through the whole thing without luck, Everything seems to be as it should but it still wont work correctly.......I give up!!
    Oct 2006
    Can you post up your cal link txt file as well as a log of this happening?
    The Tremor at AIR
    Mar 2007
    Here is the file, Ill get a log for you to look at...
  1. Desired Airflow Question, not your normal question
    By Dale in forum General (Petrol, Gas, Ethanol)
    Last Post: October 1st, 2010, 11:10 AM
  2. Locked out timing question for boost setup question??
    Last Post: September 13th, 2005, 03:22 PM
