Are the tap cells reset every time I do a reflash?
2008 Duramax LMM
- EFI Live
- EGR block
- MBRP 4" Turbo Back exhaust
- Transgo Jr
only if you reflash the tcm I believe. Before you agree to the legal agreements right before a flash, there will be a tab on the top of that window called "taps" there you can choose whether or not to reset the taps
07 El Bee Zee
Little faster than stock...
