Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: > > > RoadRunner FAQs < < <
    Nov 2006
    Default > > > RoadRunner FAQs < < <
    Most of this is obvious stuff but, maybe it will help a few people.
    Connect/Disconnect to RR step #1
    Download/Upload tune file step #2
    Emulation on/off - must be on for RTACS to work
    Filter Sets - at least 1 filter must be configured
    RR Control Panel - displays the control panel, technically step #1
    Enable/Disable Edit Mask -select this, then highlight the cells you want untouched by RTACS,
    then add the selected cells to the Edit Mask
    Fine/Course Control - set values in the Roadrunner properties tab,one of these must be selected for RTACS to work
    Column Data - value of linked PID from cal.link.txt
    this must match the column data of the table you want to use RTACS with
    Row Data - value of linked PID from cal.link.txt
    this must match the row data of the table you want to use RTACS with
    Data for RTACS - value of and, the linked PID that will alter the table with RTACS ,
    if there are no values in these boxes you must configure the cal.link.txt or,
    the PID linked in the cal.link text is not selected in the scan.exe
    Accuracy % - cells stop adjusting within this limit
    Minimum RTACS Limit - cells values will not go below this limit, if idle is rich try dropping this value
    Maximum RTACS Limit – cells values will not go above this limit, make sure this is not too low when doing WOT tuning
    cal.link.txt editing:
    RTACS supports Addition, subtraction, multiplication and division as well as the current BEN factor percentage adjustment.
    Just add the operator (+, -, * or /) you wish to use followed by a comma before the first PID name in the *.RRR key like this:
    Bxxxx.RRR=+,<pidname> Leave it blank to use the standard BEN factor %.
    Example #1:
    ;Desired Airflow
    B4307.ROW=SAE.ECT
    B4307.RRR=+,CALC.RAFIG,CALC.RAFPN,CALC.RAFACIG,CAL C.RAFACPN
    This will ADD+ the logged RAFIG amount to B4307.
    Example #2:
    ;High octane spark map
    B5913.ROW=SAE.RPM
    B5913.COL=GM.DYNCYLAIR_DMA,GM.CYLAIR_DMA,GM.DYNCYL AIR,CALC.CYLAIR
    B5913.RRR=-,GM.KR
    This will subtract- logged KR from B5913
    cal_link.txt
    LC-1 WBO2
    Jan 2007
    Good job!
    I'll add something worthwhile as soon as I get time.
    To increase or decrease the amount by which the Roadrunner updates the values.....
    Edit, Properties...
    Click 'Roadrunner' tab.
    I usually set the coarse control at something like 300. After 10 minutes of driving I'll knock it back to 100.
    I then set fine control to 50, then another 10 minutes or so and I set it to 10 and keep on fine control for a while to get as close to perfect as possible.
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Nov 2006
    Thanks.
    Check my spelling while you`re at it.
    LC-1 WBO2
    Lifetime Member driver456's Avatar
    In the circle that you have in purple,The small chip with the purple arrow facing down"PROGRAM RR PCM WITH SELECTED DATA" What exactlydoes that do?...............Paul
    Jan 2007
    Quote Originally Posted by driver456 View Post
    Very good question. I have no idea.
    Howard
    DUCT TAPE.
    Nov 2006
    "Program Roadrunner PCM with selected data".
    This programs the highlighted data only.
    You must manually select the data in the table first.
    Being able to upload a BIN while the car is running is awsome.
    LC-1 WBO2
    Oct 2004
    If you do not have the real time updates occurring that option allows you to send only the selected data to the ECM. Probably not something that you'd really use much, or seemingly at all
    Andrew
    EFILive Crew
    Mar 2007
    How do I see the calc BEN data in the map in the Scan Tool? Do I use the AutoVEPrimary.map and load it? I read how to do it before and did it but now I need to do it again.
    If I don't have the AutoVEPrimary.map, what is the function to create it?
    Jan 2007
    You deffinately should have the map Eric. I'm pretty sure they're all in there for the various widebands.
    Howard
    DUCT TAPE.
    Jan 2007
    I use the {B101}Main VE table - PLX wideband BEN
    Howard
    DUCT TAPE.
  1. What Can I Do with RoadRunner?
    By Chalky in forum RoadRunner Real-Time PCM Emulator
    Last Post: October 14th, 2012, 07:55 PM
  2. LLY Roadrunner?
    By Cougar281 in forum RoadRunner Real-Time PCM Emulator
    Last Post: January 14th, 2007, 06:46 PM
