Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: > > > RoadRunner FAQs < < <
  1. #21
    And... enter your RR license in the V7 tunetool, go Help->Register EFILive...
Name:	20160407@190216@License Manager.png
    You can see in my pic that I have 2 RR's.
  2. #22
    Nov 2005
    Roadrunner support will not be migrated to V8 software, it will forever only be a V7 function.
    Cindy
    Sent from my iPad using Tapatalk
  3. #23
    May 2016
    I am finally licensing my RR for Efilive. I cannot find cal_links.txt in the latest 7.5 version? Do I have to revert to an earlier 7 version to use the RR?
  4. #24
    May 2016
    Found it.
  5. #25
    Did you find it... it is named "LS1_link.ini".
  6. #26
    May 2016
    Yes. Thank you.
  1. What Can I Do with RoadRunner?
    By Chalky in forum RoadRunner Real-Time PCM Emulator
    Last Post: October 14th, 2012, 07:55 PM
  2. LLY Roadrunner?
    By Cougar281 in forum RoadRunner Real-Time PCM Emulator
    Last Post: January 14th, 2007, 06:46 PM
