Results 1 to 3 of 3
Thread: 01 s-10 to LS1 swap q
    Dec 2008
    Default 01 s-10 to LS1 swap q
    Friend of mine whats to swap an LS1 in his '01 s-10 with the 4.3 vortec.
    What Im wondering is, can I use his stock computer and just put an ls1 tune on it?
    We're going to use a plug and play harness and such that is based off of what year ls1 we choose.
    As I understand there are different computers for different ranges of LS1s, so if it is possible to make his s-10 comp turn ls1, what year(s) ls1s should we look for?
    thanks.
    The S10 PCM will work. You would need to get a 1999 thru 2002 LS1 type setup. The 1997-1998 setup will not work.
    Al
    Dec 2008
    easy enough. thanks.
  1. pcm swap
    Last Post: August 18th, 2009, 07:10 AM
  2. 2.2L s-10 411 swap?
    By haulinit in forum General (Petrol, Gas, Ethanol)
    Last Post: August 5th, 2009, 06:03 AM
  3. 97-02 pcm swap ?
    By TurboVet in forum Gen III V8 Specific
    Last Post: February 19th, 2009, 01:08 PM
  4. 01 to 03 ECM swap
    By sweetdiesel in forum General (Diesel)
    Last Post: January 3rd, 2008, 06:03 AM
  5. VIN swap
    By markgammel in forum General (Petrol, Gas, Ethanol)
    Last Post: October 11th, 2007, 04:18 PM
