Results 1 to 8 of 8
Thread: how to put tunes into dsp format
    Feb 2009
    Default how to put tunes into dsp format
    i want to take 5 tunes and put them in dsp 5 format how do i do this ?
    Feb 2009
    bump to the top
    Oct 2004
    It is not a case of 5 separate complete calibrations (not nearly enough free space in the ECM) but rather a few select tables which can be calibrated to effect 5 different levels of tune.
    Check out the tutorial here (http://download.efilive.com/Tutorial...%20LBZ-LMM.pdf) for more details.
    Andrew
    EFILive Crew
    Feb 2009
    hmmm not a clue i looked at that, so your saying i cant take 5 dif tunes and put them on a dsp switch ?
    Oct 2004
    Not 5 total calibrations in their entirety. Perhaps have a look at the '2005_LLY_Duramax_DSP5.tun' sample tune. Under the 'EFILive Custom Calibrations' section you'll see how the different tunes are implemented. I don't have a LBZ/LMM DSP5 on hand to send you unfortunately...
    Andrew
    EFILive Crew
    Feb 2009
    can u send me the link to that please
    Oct 2004
    It is included in the default software installation. It will be in your 'My Documents\EFILive\V7.5\Bins' folder.
    Andrew
    EFILive Crew
    You would need to open up each of the 5 tunes and manually copy over the tables in to the DSP5 section. As Andrew said, it's not like 5 totally separate tune, DSP5 contains the main tuning tables only.
  1. New DVD format
    By Chevy366 in forum Lounge
    Last Post: October 26th, 2009, 05:44 PM
  2. Logging format
    By Spindoctor in forum General
    Last Post: April 30th, 2008, 05:46 AM
  3. CAL file format
    By runrun in forum Tips and tricks
    Last Post: August 28th, 2007, 06:40 AM
  4. Unknown bin file format.
    By serpa4 in forum General (Diesel)
    Last Post: July 5th, 2007, 06:01 PM
  5. Speed Density Format
    By Murillo5oh in forum General (Petrol, Gas, Ethanol)
    Last Post: November 23rd, 2006, 10:43 AM
