Results 1 to 2 of 2
Thread: Couple of LMM Questions
    Default Couple of LMM Questions
    Ross/Paul, couple of questions. Can you program the injector flow rate with the V2 without using a license, as you can do some other things such asl PCM locking? Also, is there a crank relearn on the LMM that you need to do when you replace the ECM? A Friend of mine just ordered a LMM ECM from ECUOutlet, and he said they mentioned something about a crank relearn. Is there anything other than Injector flow rate that needs to be programmed to the ECM?
    You don't need to use a license to copy the Injector flow rates.
    I don't recall any CASE Learn options for the LMM ECM in the TechII.
    It might also need to do a VATS relearn, but maybe not as these are brand new ECM's with blank VATS codes then they should auto learn without scan tool intervention.
  1. A couple of questions about autove
    By tokymon in forum Vortec V6/V8 Specific
    Last Post: August 4th, 2009, 08:56 AM
  2. Couple Newbi questions
    By gpr in forum Gen III V8 Specific
    Last Post: August 3rd, 2009, 07:46 AM
  3. couple of questions ...
    By drdarthinvader in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: December 4th, 2008, 02:33 AM
  4. Couple little questions
    By samdweezel05 in forum Duramax LB7
    Last Post: November 22nd, 2008, 05:25 AM
  5. couple of questions.....
    By WHYTRYZ06 in forum Custom Operating Systems
    Last Post: March 16th, 2008, 05:37 AM
