Ross/Paul, couple of questions. Can you program the injector flow rate with the V2 without using a license, as you can do some other things such asl PCM locking? Also, is there a crank relearn on the LMM that you need to do when you replace the ECM? A Friend of mine just ordered a LMM ECM from ECUOutlet, and he said they mentioned something about a crank relearn. Is there anything other than Injector flow rate that needs to be programmed to the ECM?
