Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: BBL Pids???'s
    Aug 2008
    Default BBL Pids???'s
    I'm using the LS1B_M for BBL my S-10 Vortec but it won't let me use KR or AFR....
    I've tried using KR & KNKRET_B and also AFR & AFR_B
    both of them unsuccessful though
    After i change the pids in the option_text my V2 validates KNKRET_B and AFR_B but they don't show up on the V2 LCD or on my laptop when I view a Log
    And if I use AFR and KR, V2 tells me they are not supported...
    But the funny thing is, I always use KNKRET_B and AFR_B when I use my laptop/V2 for data logging...
    Any Ideas?
    FLASHSCAN V2 & AUTOCAL
    Oct 2004
    The PIDs in Version 8 (Black Box Logging) are sometimes different to the PIDs in V7. Have a look at the PID Description files in the ‘C:\Program Files\EFILive\V8\Documents\Pid Descriptions’ folder
    Neither of the PIDs you mention are listed in the LS1B_M file.
    Andrew
    EFILive Crew
    Nov 2006
    KR [1] Retard Due to Knock (°)
    and
    AFR [2] Commanded Air Fuel Ratio (AFR)
    are on mine.
    did you write them like this?
    PCM, KR
    PCM, AFR
    If you want a calc.pid use "-", PID
    LC-1 WBO2
    Aug 2008
    Quote Originally Posted by mr.prick View Post
    and
    are on mine.
    PCM, KR
    PCM, AFR
    Yes, I wrote them exactly like that... Since there isn't a Pid selection available for Vortec controllers in the V2 for BBL, Paul told me I can use either LS1A or LS1B in the V2 but i would have to find out which Pids were supported and which one's were not and to modify accordingly in the options_text file
    EOPS, KR and MAFFREQ weren't supported when I started, I removed EOPS and MAFFREQ an replaced with SHRTFT1 & SHRTFT2
    I replaced KR with KNKRET_B (only works with Vortec controllers)
    Replaced AFR with AFR_B (only works with Vortec controllers) and it worked but the problem is they don't show up on the V2 LCD screen and they didn't show up when I put the SD card in my laptop to view a log file. That's as far as I got...
    Aug 2008
    It must be something simple that I'm missing...
    Can you send me your Options.txt file? (paul@efilive.com)
    Aug 2008
    Yes, Sir....
    Ok, after looking over the files that you sent, I can see what is causing the problem.
    You can only select the PIDs listed in the appropriate pid description files in the folder: \Program Files\EFILive\V8\Doc\Pid Descriptions
    The only controller type that is currently defined to support the AFR_B PID is the E40 controller, so you'll need to use that one (for your vortec) in order to see the AFR_B PID.
    Unfortunately (right now) there is no *.pmm file that is configured to display the KNKRET_B PID. So you can't log that using BBL at the moment.
    Right now I am working on updating the BBL PID selections and a vortec definition should be availabel in the next update.
    Aug 2008
    Thanks Paul, I'll be looking forward to it....
    Aug 2008
    Hey Paul,
    I see there was a new update. Any chance a Vortec BBL definition was included? Just curious...
  1. How to add my PIDS to BBL?
    By DrkPhx in forum FlashScan V2 BB Logging
    Last Post: March 15th, 2009, 11:59 AM
  2. BBL PIDs
    By mr.prick in forum FlashScan V2 BB Logging
    Last Post: July 4th, 2008, 04:26 PM
  3. ETC PIDs?
    By DrX in forum General (Petrol, Gas, Ethanol)
    Last Post: June 3rd, 2006, 03:27 AM
  4. PIDs
    By nonnieselman in forum General (Petrol, Gas, Ethanol)
    Last Post: May 12th, 2006, 03:47 AM
