Anyone know if there is a bench harness available for the P12? For sale that is...
Might have to make break down and make one but I would rather purchase one...
FLASHSCAN V2 & AUTOCAL
I just read the Bench Harness Tutorial and it says that the E40 and the P12 have the same pinout...So that means I can use an E40 Bench Harness and it should work...
Cool.....
Correct, My bench harness with that style connector does 6 different ECM types.
E40 (V8) , P05 (V6), P11 (4cyl), P12, LLY, E22 Northstar.
I might have to make one here soon for the P10...only problem is there arent any other PCM/ECMs that use the same wiring harness. Oh well, Im just really mad GM has killed the I6 for good :(
