D0914 Transmision Calibration:
Maximum speed before the PCM will force an upshift to 2nd if the gear lever is being held in 2nd.
This is on:
OS - 12579405
Cal - 12580788
This is on:
OS - 12579405
Cal - 12580788
2003 Chevy S10 4.3L LU3 LS1B Auto
48 LB injectors
Race Proven Motors 2114 intake
T70 turbo.
On some transmission calibrations/controllers, selecting Manual 2nd keeps the transmission in 2nd gear except under excessive throttle in which case the controller selects 1st gear (regardless of the shift lever being in M2 position)...
D0914 controls when the controller upshifts to 2nd during that situation.
Not all controllers do this.
Makes sense now! Thanks Joecar!
48 LB injectors
T70 turbo.
If this table were zero'ed out, would it always hold second gear, or would that potentially cause a problem?
I'd love to have the "2" position hold second under all throttle positions. It would come in handy, e.g., climbing road to Brian Head peak at 11,000 ft with 6 people and 6 downhill bikes in the truck....in that situation I may want more power, but I certainly don't want first gear.
Yes, I believe so, all zeros will hold 2nd in M2... I remember placing non zero values in D0914 allows WOT 2->1 while in M2
Thanks, I'll give it a shot then.
