Results 1 to 10 of 10
Thread: License
    Feb 2009
    Default License
    I really wanted to try this software but the evaluation licence does not work for me. :(
    Everything is entered correctly as posted in the sticky but no go. :(
ID:	4651   Click image for larger version.
    Vyking, I pm'ed Tech Support.
    Feb 2009
    Thanks joecar, I've done as suggested.
    Oops ... maybe you meant you PMed for me ..... If so thanks.
    Feb 2009
    Does anyone ever answer pre-sales or support questions?
    They don't seem to be very professional.
    Hmmm, they usually do... They must be out of office... I pm'ed Tech Support again.
    Apologies, email has been down for a while. I don't know why yet.
    Did you download the Eval or the Pro version? The Pro version won't work with the Eval license.
    Feb 2009
    Thanks Paul, all sorted now.
    I was trying to use the Pro version.
    May 2009
    Quote Originally Posted by Vyking View Post
    Im also having the same problem, license key is not working.
    Im also using the eval software.
    Any help would be great . Thanks
    Quote Originally Posted by 5.7senator View Post
    Make sure there are no spaces at the start/end of the data you are entering.
    Make sure you don't have anything entered in the fields that are blank.
    If all else fails then use the [Load] option in the registration screen to load the license from the attached file.
    May 2009
    Thanks Paul , i used the attached file and it worked.Thankyou.
  1. V2 License
    By Yortt in forum Gen IV V8 Specific
    Last Post: November 14th, 2008, 12:17 PM
  2. v2 license
    By 94caprice00gmc in forum FlashScan V2
    Last Post: April 18th, 2007, 12:00 PM
  3. Flashscan has license avail. but won't let me license PCM
    By Wasted Income in forum Purchase and Shipping
    Last Post: April 6th, 2007, 10:25 AM
  4. Need license key!!!
    By limited cv8r in forum RoadRunner Real-Time PCM Emulator
    Last Post: January 8th, 2007, 09:46 PM
