Results 1 to 3 of 3
Thread: Install help please...vista...run as administrator..cant open calc_pids.txt
    Jan 2006
    Default Install help please...vista...run as administrator..cant open calc_pids.txt
    I installed the 7.5 from the main page downloads section
    wanted to play with it before I buy it..
    installing on vista
    and it opens with an error about not being able to find cal_pids.txt
    and then closes the whole thing..
    HELP?!!
    edit:
    Error report generated by EFILive at 11:48:23 on Feb 04, 2009
    Error code: ERR_WIN 0/0
    Cannot open file "C:\EFILive\V7.5\User Configuration\calc_pids.txt". The system cannot find the file specified
    EFILive Version: 7.5.5 (Build 78)
    Platform: Windows NT
    Version: 6.0 (build 6001)
    Processor type: Pentium 1995MHz
    Directories
    Temporary Cache: \EFILive\V7.5\Temporary cache
    Logged Data: \EFILive\V7.5\Logged data
    Customers: \EFILive\V7.5\Customers
    Configuration: C:\Program Files\EFILive\V7.5\Configuration
    Exported Data: \EFILive\V7.5\Exported data
    Images: \EFILive\V7.5\Images
    Sounds: \EFILive\V7.5\Sounds
    Maps: \EFILive\V7.5\Maps
    Pids: \EFILive\V7.5\PIDs
    Virtual Dash: \EFILive\V7.5\VDash
    Print Reports: \EFILive\V7.5\Print reports
    Bug Reports: \EFILive\V7.5\Bug reports
    Connected: No
    Auto connect: No
    Scan OBDII info: No
    Error retries: 1
    Retry delay: 10
    Message throttle: 0
    Most recently used VIN: xxxxxxxxxxxxxxxxx (Note: 1)
    PCM information
    Unknown: Unknown
    Unknown: Unknown
    Unknown: Unknown
    Unknown: Unknown
    Unknown: Unknown
    Unknown: Unknown
    Unknown: Unknown
    Unknown: Unknown
    Unknown: Unknown
    Unknown: Unknown
    Unknown: Unknown
    Unknown: Unknown
    Stream-Slow scan mode: Unknown
    Stream-Fast scan mode: Unknown
    Maximum dynamic packets: Unknown
    Most recent communication with vehicle:
    Report ID: 114046 (Note: 2)
    Notes:
    (1) The VIN sequence number is not required for this report and for your privacy it is NOT included in this report.
    (2)The report ID is a checksum of the report text and is used to verify the integrity of the report.
    Did you accept the default folder locations when installing?
    Vista is so anal about where software gets installed.
    The EFILive default install folders are:
    \My Documents\EFILive\V7.5
    and
    For some reason, the software has configured its registry settings with the calc_pids.txt file is located here:
    Normally it is located here:
    \My Documents\EFILive\V7.5\User Configuration\calc_pids.txt
    On Vista I recommend uninstalling and re-installing with the default folder options selected. If you are asked to delete the registry settings during the re-install, select "yes" to delete them. Those registry settings are the ones that contain the folder locations and by deleting them, it will allow EFILive to set them up correctly again.
    P.S. Once the software is up and running, you can change the folder locations in the Scan Tool Properties window on the Folder tab page.
    Jan 2006
    and
    I copied the files from the my documents folder to the one it was looking...it works now...thanks
  1. calc_pids.txt?????
    By the4wheeler in forum General
    Last Post: October 23rd, 2008, 04:23 PM
  2. Vista install ???
    By Slowrc in forum General (Petrol, Gas, Ethanol)
    Last Post: May 23rd, 2008, 01:06 PM
  3. How do I install the drivers for my V2 on Vista?
    By AustinL911A in forum General (Petrol, Gas, Ethanol)
    Last Post: June 21st, 2007, 02:39 PM
  4. LC-1 calc_pids file and sae_generic files
    By BowlingSS in forum General (Petrol, Gas, Ethanol)
    Last Post: July 26th, 2005, 12:44 AM
