Results 1 to 8 of 8
Thread: 2002 Z06 with unstable idle & rich mixture
    Aug 2008
    Default 2002 Z06 with unstable idle & rich mixture
    Hello everyone. I have posted this question a couple of times and you guys have done nothing but try to help me. Thanks for everything. I need to ask for help one more time. I have tried all the advice, used the tutorials and beat my brain for the last month on this car. The vehicle has a new engine with a comp G1 camshaft, and borla exhaust. everything else is stock. When the vehicle is started the idle will rise to about 2000 rpm then drop down to about 600 and the computer will try to compensate but cant keep up then the vehicle will die. I have attached my tune file. Will someone take a look at this and let me know what im doing wrong. Please. Thanks ahead of time for all your help
    Jan 2008
    It's been so long, but I remember this like yesterday, wait I had the same problem yesterday too
    Makes me warm all over to see some things never change.
    97 MN6 vette, Vortek, BBK 80 FAST 78 manifold, 42# racetronix, lingenfelter edlebrock heads 202cc, 228 232 .622 .630 111+2, patriot dual ex, yt roller rockers, lg pro, now with cats, .041 Mr. Gasket (cometic leaked), 62cc head, ~60 cc chambers, custom built coilovers, ADDCO sway bars
    Oct 2006
    Quote Originally Posted by kmidkiff View Post
    Have a look at B0107 & B0108. With these both set at 0 you will not enter idle mode. Try B0107 at 3 & B0108 at 1.2.
    Also it will help if you post a log.
    The Tremor at AIR
    Jul 2008
    1. VE Table B0101: Looks like you are still running the stock VE table..perhaps cut 10-20% fuel in the 400 & 800 rpms line.
    2. Desired Aiflow B4307: Have you done RAFIG? If not, try adding .5-1.0 g/s across the board.
    3. Startup Friction Air B4343: Add 2-3 g/s across the board.
    4. Direct Airflow Correction: B4515: Might double-check your values. You have some unusual values in RPM Low Drive..re-check Idle Tutorial for values.
    5. Spark Tables B5913 & B5932: Are you still using stock? 17 degrees of timing in base gear for idle is really low for a cammed car. If nothing else just cut & paste Spark High Octane B5913 into B5932.
    A lot of your tune appears to still be stock. Most likely your Base Spark is just way too low, and your Direct Airflow Correction Table needs some work. Check SSpdDmon's Idle tutorial tune. If you check 'idle' on search, he has numerous tunes attached that addresses questions just like yours. It worked quite well for me.
    Oct 2003
    I Would "lock up" the <1200 rpm timing @ ~30-35* so you don't jump into a hole with adjacent cells. That will lean it up, but probably not enough. Add air ..
    PowrMax Performance
    100 mm PowrMAF
    May 2007
    Bruce what do you mean with the timeing? all cells in the 400,600,800,1000,1200 should b e the same or just up to say .28 grams? I am trying to get mine to idle better with a 239/ 243 cam.
    2000 NBM trans am.
    427 Dart ship block,Lme ported Ls7 heads 12.5 compression
    246/262 .730/.712 112+4 low lash solid roller
    Rmvb 4l80 with transbrake, 8" FTI converter
    12 bolt Moser rear end with 4.10 gears
    Oct 2003
    Quote Originally Posted by Aint Skeered View Post
    all cells in 400-1200 rows should be ~30 or 35*. This is a no real load area and it will help with the cam overlap.
    PowrMax Performance
    100 mm PowrMAF
    May 2007
    Thanks bruce, Timing fixxed my surging alon with a couple other minor tweaks in the tune but timing did the most good of all.
    2000 NBM trans am.
  1. can not set idle to correct fuel mixture
    By pullincrazy88 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 15th, 2009, 03:46 PM
  2. Unstable Idle
    By kmidkiff in forum Gen III V8 Specific
    Last Post: January 29th, 2009, 07:29 PM
  3. Car Wont Idle And Runs Rich At Idle ( Tune Inside)
    By mikeyayell in forum Gen III V8 Specific
    Last Post: January 8th, 2008, 04:17 PM
  4. Rich idle
    By gcross in forum Gen III V8 Specific
    Last Post: January 10th, 2007, 02:35 AM
  5. Stock maf = perfect idle. Big maf = unstable idle. Any tuning suggestions?
    By onfire in forum General (Petrol, Gas, Ethanol)
    Last Post: July 11th, 2006, 03:58 PM
