Results 1 to 5 of 5
Thread: Vehicle XML file for 1992 buick lesabre
    Feb 2009
    Default Vehicle XML file for 1992 buick lesabre
    I'm new to this world and looking for the best or closest xml file I can use for a 1992 Buick LeSabre Custom. The PCM is 16141470.
    I willing to do some work to build one - if necessary - I am an IT developer and work with XML regularly. I'm just not sure where to start.
    Any advice would help.
    Feb 2009
    Default Follow up
    Also - I am only looking to read trouble codes and basic engine information - not doing any programming of the EPROM.
    The data streams are defined in *.ds files available here:
    ftp://ftp.diy-efi.org/pub/gmecm/
    Download the file ALDLstuff.zip
    There is a word doc in that zip file that shows you the correct *.ds file for your application, based on engine size, 8th digit of VIN, year etc.
    You should also take a look through the *.xml files that come with V4 and check if any are a close match to yours. Look in the "Edit->Vehicle" window.
    See example screen shot.
    P.S. You don't have to work with the xml directly, the software has a data stream editor built in.
    Handy hint: when entering trouble codes of bit flags (8 at a time), it is a good idea to try and use the Ctrl+A and Ctrl+B paste options to copy all 8 rows at once. Look up how they work in the html doco.
    Feb 2009
    OK - I'm making progress - but I have a question.
    On the ALDL (F7) tab I only see 8 properties/measurements - even though many more are defined in the XML file. This is true whether or not the I am connected to the car's port.
    On the DTC (F10) tab, I only see 8 DTC values.
    Is this a limitation of the evaluation version, or am I missing something else.
    Quote Originally Posted by MarkS View Post
    Yes, its a limitation of the eval version. See the doco under: Release notes->Pro V's Eval.
    Send me an email (paul@efilive.com) with the definition so far and I'll send you a Pro license so you can continue to develop the definition more easily.
  1. 95 buick lesabre
    By danshot in forum EFILive V4
    Last Post: January 6th, 2010, 09:49 AM
  2. What Vehicle Def For a 94 Buick 3800
    By TucsonDirect in forum EFILive V4
    Last Post: January 4th, 2010, 09:58 AM
  3. ALDL Timing - Buick Roadmaster
    By 91olds98 in forum EFILive V4
    Last Post: March 30th, 2009, 01:29 PM
  4. Vehicle file for 1994 Pontiac Bonneville SSEi
    By kjhansen in forum EFILive V4
    Last Post: October 21st, 2008, 04:52 PM
  5. Buick SC 3.8 ?
    By Boost in forum General (Petrol, Gas, Ethanol)
    Last Post: January 23rd, 2007, 03:14 PM
