Results 1 to 6 of 6
Thread: First working AFM in a Gen IV swap
    Apr 2008
    Default First working AFM in a Gen IV swap
    I finally made it through..;-))
    see: http://forum.efilive.com/showthread.php?t=9960&page=2
    If nobody has done it before, somebody has to do it....
    1997 Tahoe 2dr 4WD
    2002 Alfa Romeo Sportswagon 2.0 JTD
    1982 Deutz Intrac 2004A
    2003 friesian Horse " Henry"
    Aug 2008
    That's great....Sounds like it was a bunch of work...
    FLASHSCAN V2 & AUTOCAL
    Good job Harald...
    Nov 2008
    Default Afm works!!!
    Downloaded the 2WD tune from a Tahoe and AFM is enabling. I can accelerate slightly in AFM mode probably because my truck is so light, but I would like it to stay in longer.
    Noise is acceptable, but has a slight vibration while in 4 cyl mode. It's not too annoying so I can live with it. I am using early small block mounts with adaptors since there is not room for the dampened mounts.
    Thanks Ross and Harold
    Apr 2008
    Default Well done...
    Robbie,
    as soon as you do something correct it works. Now after all it wasn't that hard at all.
    We still have to find a way for the rest of the swap crew to get the whole thing working with 4wd tunes in TCM and ECM..... we will see.
    1997 Tahoe 2dr 4WD
    Nov 2008
    Default 4 Lo Invalid
    I believe the invalid 4 lo signal is affecting more than just AFM in the ECM/TCM 4WD tune.
    Since switching to te 2WD tune my transmission kicks down and downshifts correctley(no changes to TCM); and the engine is more responsive with the same fuel and spark tables. Your right again Harold, for the 4WD tune to work it needs a valid 4 lo signal. Too bad it can't be done through just a hardwire?
  1. DSP 5 not working
    By minytrker in forum Duramax LB7
    Last Post: March 9th, 2010, 10:22 AM
  2. C.A.S.E not working
    By uaesands in forum E37, E38 & E67 PFI ECM's
    Last Post: September 25th, 2009, 02:38 AM
  3. Alternator not working after PCM swap, HELP
    By edwardzracing in forum Gen III V8 Specific
    Last Post: May 29th, 2009, 05:48 PM
  4. E40 DMA Not Working
    By Forcefedperformance in forum Gen IV V8 Specific
    Last Post: July 27th, 2008, 05:50 PM
  5. V2 not working with win 98
    By Buzzard in forum FlashScan V2
    Last Post: April 6th, 2007, 10:07 AM
