yeah i know k type
yeah i know k type
Ross, I just connected to my LBZ ECM, and did a Validate PIDs. After validating the PIDs, There's a "CATEMP1" and CATEMP2" (Catalyst Temperature Bank 1 - Sensor 1 & 2). There is no "Exahust Temperature" PID in the list (that I could find) in the V7 tool for LBZ or LMM. Under the BBL PIDs, there's EGT1A and EGT2A under the LMM PIDs, and CATEMP11 and CATEMP12 under the LBZ PIDs. Before I go steal a probe from a friend that has a de-DPF'd LMM, do you think the CATEMP PIDs are for the EGT Pins on the ECM?
CATEMP1 & CATEMP2 are SAE defined PID's, the ECM must support them.
GM.EGT1A & GM.EGT2A are specific PID's in the Bosch ECM for the EGT probe temps. I actually don't know if they produce the same numbers as the SAE PID's (I would doubt it).
If on the LBZ GM.EGT1A & GM.EGT2A don't validate then GM probably have the PID disabled. Now, it might be possible to enable it as a valid PID, but that does not mean it will work still, there might be some underlying tables that need to be set up to make the EGT probes come to life.
I've got some probes here I can hook up and see if I can make the LBZ ECM read them. I'm 99% sure it will be possible to make them work because the EDC16 ECM's all have the DPF processing code in them.
What OS are you guys running? I'd like to concentrate on one only during testing.
Operating System 12606128
Engine Operations 12606145
6128 seems to be the most common
4138 is a little older and not so common
6698 is newer (i think) and i haven't seen it around much
I spent 4 hrs on this today and still I can't get the PID to validate on the LBZ ECM, typical Bosch frustration.
I know the EGT pins, the quest is to make the LBZ ECM allow the EGT PID's to be validated.
Yes, we have been working on some more tables for the Bosch ECM. One of them is the MAF flow table for the frequency style MAF's.
