Results 1 to 3 of 3
Thread: stuck in 3rd??????
    Aug 2008
    Default stuck in 3rd??????
    this is the weirdest thing i've just finished replacing the valve springs on my vx ss ls1 with duel springs and went for a drive it threw these dtc fault codes
    p0740-tcc enable control solenoid
    p0748-pc solenoid a control circuit
    p0753-shift solenoid A
    p0758-shift solenoid B
    p1860-tcc pulse shift width modulation pwm solenoid
    my 4l60e is stuck in 3rd but can manual shift 1st to 3rd and have reverse
    need advise........thanks
    Dec 2007
    has the harness pulled out of the trans plug ???
    check that first id say
    Aug 2008
    thanks for that i lent over the fuse box and the fuse for the transmission was detached it also supplies power to the maggie water pump it was a temp fitting
    well thats what ill be replacing thanks
  1. E38 stuck in 4lo..??? Pls help...
    By harascho in forum Gen IV V8 Specific
    Last Post: January 28th, 2009, 06:56 PM
  2. 4L80-E stuck in 2nd
    By jpsxpress in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 3rd, 2008, 04:12 PM
  3. V2 stuck in reboot after 2.05.10 FW
    By Treurentner in forum FlashScan V2 BB Logging
    Last Post: December 3rd, 2007, 09:18 AM
  4. Help tuning with MS4 Cam! I'm stuck
    By Kevin Doe in forum General (Petrol, Gas, Ethanol)
    Last Post: October 9th, 2007, 03:34 PM
  5. Triple Dog stuck in my PCM???
    By WildChild in forum General (Diesel)
    Last Post: July 9th, 2007, 06:47 AM
